What is a craft knife? - Office Equipment & Supplies
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
You use this instead of scissors when making craft projects. It is used to make precise and detailed cuts on paper or cards. You should always use it with a cutting mat to protect your table and to protect the knife's blade.
Posted on Jan 17, 2013
Can I make an envelope if I do not have the scoring stylus?
You can use a craft knife and steel rule on a cutting mat.
Or
You can buy envelopes.
Jan 07, 2018 | The Office Equipment & Supplies
How long to roast 0.88kg pork leg?
1 hour at 350 deg or 175 c
Apr 29, 2016 | Ovens
How to replace spiral rubber that are riveted on?
Pieces of old conveyor belt, a craft knife, a drill and a pop riveter. Is what I would do. Or you could drill the old pop rivets out and use stainless steel nuts and bolts for ease of replacement.
Jan 26, 2016 | Garden
What do I need to install this wall mount the tools
To fit my tv to the wall
rubber mallet to knock in wall plugs
drill and bits
power drill/driver
spirit level
craft/stanley knife
Jul 19, 2015 | Televison & Video
How do you remove old grips?
I usually cut them off with a craft knife, when putting on the new ones soak them in very hot water it softens them up allowing a tight fit.
Aug 03, 2014 | 2000 kawasaki VN 800 Vulcan Classic
Can I fly with a craft knife in my carry on? it has a retractable blade?
As a rule of thumb I wouldn't recommend taking a knife on a plane because you run the risk of it getting confiscated even if it is retractable. You would be better off sending it in checked luggage under the plane.
Sep 23, 2013 | Office Equipment & Supplies
I'm doing a rubber stamping project. Should I buy a craft knife?
Yes, you should. craft knives are really useful in rubber stamping. A basic craft knife is all you need. You use the knife to carve the design you want.
Jan 17, 2013 | Office Equipment & Supplies
Static when I turn on speakers or adjust volume
The problem is that the switch/volume control is dirty.
This is what I have done.
Dismantling Altec Lansing VS 2221 speakers to clean the switch/volume control
Tools: a medium Phillips screwdriver, a craft knife & a can of CO contact cleaner & extension.
1. Remove switch/volume control knob by pulling it off
2. Pull out the base for the stand if attached
3. Unscrew the 2 screws beside the wires
4. Remove the front gauze by prising it out from one of the bottom corners. Keep the gauze straight as it will need to be put back from the bottom to the top.
5. Remove the 2 screws at the top and the 4 long screws holding the speaker. The back will come apart from the front and sides. If it has been glued then use the craft knife to carefully cut the back away from the sides and/or prise it away with a little pressure on the sides.
6. Attach the extension to the can of contact cleaner.
7. Lift the circuit board out and squirt only the switch/volume control. Ensure you squirt the shaft and the internal parts of the switch/volume control. Turn the shaft a few times.
8. Allow the contact cleaner at least 1 hour to dry.
9. Test the speakers. If the noise is still there then repeat steps 6-9.
10. To assemble the speaker do the steps 1-5 in the opposite order.
I hope this is helpful
Jan 26, 2010 | Altec Lansing VS2221 Computer Speakers
Need to replace a targa valve on a astracast targa monobloc tap
the cover on the outside should pop off, and there should be a crew there, sometimes they are a little tricky to get off, a craft knife of something like that should do the trick
Jan 17, 2009 | Plumbing
Lg Glass/mirror replacement
For screen replacement the best solution is to consult hardware vendor.Doing it urself could damage intrernal parts of the phone
Oct 19, 2007 | LG Shine KE970 Cellular Phone
771 people viewed this question
k24674
jasbo
jasbo
