Question about Lexmark X340n All-In-One Laser Printer
33.64 chg.cart.invalid refill
No work when start
3 Suggested Answers
  • 11 Answers
SOURCE: lexmark error: 33.64
Change Toner cartridge.
Do not refill your toner cartridge in the same place anymore ;) Do not refill them like 10 times ;) Use original toners for your MF/Printer
Maxi
Posted on Nov 20, 2009
passionat423
  • 253 Answers
SOURCE: lexmark x340 shows this eror
CHANGE CHIP OF CART.
Posted on Feb 05, 2011
That appears " change cartridge invalid refill
Ether the cartridge was refilled wroung or there is a issue with the print head, your going to need to take the refilled unit back where it was filled at, if that is not the case then the print head is not reading the cart.
Oct 12, 2010 | Office Equipment & Supplies
HP 2210 all in one chg black cart, get message
Do a powerflee of the printer..
take out the black cart. Unplugged all cables
including powercable. press and hold the powerbutton for 30 sec then put back the cable and the black cart.
May 07, 2010 | HP PSC 1210 All-In-One InkJet Printer
Get refilled ink cart. to work
probably one of your cartridge is no good
check the contacts ..try clean them with
a wet towel
Apr 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Lexmark error: 33.64
Maxi
Feb 18, 2009 | Lexmark All-in-One Printer with PictBridge
After changing ink cartridges, I am getting pages that have light and dark printing on it like it is running out of ink but it only last until the printer gets hot. It starts back doing it if the printer...
In most cases for Inkjet printers. The cart chg disruption causes a sort of air lock in the ink flow lines. 99.9% of the time you just need to do a head clean.
In some extreme cases (if you are using generic ink carts) you may need to install an original cart again to get the flow right. But you can go back to generic carts after that.
Jul 23, 2008 | Samsung Office Equipment & Supplies
Brother MFC5840 CN Print heads
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the it will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintenance mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of distilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exact mixture of original brother ink.
Mar 12, 2008 | Office Equipment & Supplies
Stuts,
If you re lucky the ph will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintnenace mode.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of destilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
This is -nearly- the exacte mixture of original brother ink.
Mar 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Lexmark X340n All-In-One Laser Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
