Question about Brother DCP-J525W Colour Inkjet Multifunction Multifuncti
How to change wifi code
My wifi code changed so how do i reconfigure printer with the changed code
I cannot print with my Mac Book Pro. Correct printer is added already.
The mapping info is lost after the router and wifi change . Reconfigure the laptop settings for this . My previous answer would be invalid because you dis not mention WiFi
Jun 24, 2015 | Office Equipment & Supplies
Wifi password reset
Once you log into your router click on the wireless link.
On the bottom of the wireless page click security.
Here you can change your wifi security.
Once done just click apply and the that's it.
Note: Once you change the wifi security settings you will have to reconfigure your wireless devices with the new wifi security.
Ref: http://www.dlink.com/us/en/support/product/-/media/Consumer_Products/DSL/DSL%202640B/Manual/dsl2640B_Manual_100.pdf
Dec 20, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
My son went to youtube and found a video on how to change WPA to WEP. Now my network is not working on my printer and laptop
you need to reconfigure your printer and laptop to WEP but I don't recommend it as WEP is terrible and easy to crack.
connect to your router via cat 5
open internet explorer and browse to http://192.168.1.1
login with the default login is blank. pass is admin.
go to wireless and to wireless security.
change it back to WPA personal.
change the passphase for the wireless password.
use the new passphase you created and tell your printer/laptop to join your wireless network
you may want to change your wireless password too so your son won't reconfigure your router again.
do this by going to administration and change the password there.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
Hi there i have just changed from ADSL cable in put to ADSL2 wi-fi but my wi-fi needs updating is this correct ? if so how do i do this
Just changing or replacing the ADSL Cable ie if it is the Network cable (RJ45) will not affect the configurations of the router in your WIFI modem. Update is not necessary.
Replacing your WIFI modem set, you have to reconfigure the wireless modem router settings to get acess to your internet.
Read the setup instructions manuals if you are replacing your WIFI set.
Hope it helps.
Nov 15, 2010 | Acer Computers & Internet
I have a lexmark x4690 wireless printer. I had to change my bell sympatico dsl router. Now I need to change the network on my printer but I can't. I no longer have the driver cd and I tryed downloading...
You will need to reset the printer's wireless network adapter then reconfigure it with your new wireless network settings. On the printer's operator panel, press Setup button > Network Setup > Reset Network Adapter > hit Ok. The Wifi light will momentarily turn off then will turn on orange. Once you have that, run the Lexmark wireless setup utility on your computer to configure the printer with your new wireless network settings. Thanks.
Aug 04, 2010 | Lexmark X4690 Wireless InkJet Printer
Printer not printing
You need to reconfigure the printer and set it up to the new wireless network. You have to reset the printer's network adapter. On the printer, press Settings > Network Setup, hit Ok > Reset Network Adapter to Factory Defaults, hit Ok. The wifi light will turn off for a few seconds, then will light up solid orange. Then reinstall the printer for wireless connection. Make sure to use the correct security encryption info, if there is. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 05, 2010 | Lexmark X6170 All-In-One InkJet Printer
The pound sign has disappeared from my pc keyboard, also the@ has changed it`s position to number 2 position
try reconfiguring the international settings to uk, it may have beens et to USA which is how it is confiured
Nov 19, 2009 | HP DeskJet F380 All-In-One Printer
Hi i have a lexmark all in one printer,recently i changed my router and now cant connect the printer wirelessly to the computer!
You will have to reconfigure the printer with the router and then reconfigure the PC. All routers don't have the IP address range. That might be the reason why it isnt working after changing the router. Also, if you were using the printer wirelessly, the SSID (network name) and the wireless security needs to be reconfigured to match your new router. The simplest way to achieve this would be to connect the printer hard wired to the router; uninstall the printer drivers completely from the PC; and run the setup disk again. The setup will walk you through the whole process.
Please get in touch if you need further clarifications.
regards
Sandeep
Oct 27, 2009 | Office Equipment & Supplies
Brother DCP-J525W Colour Inkjet Multifunction Multifuncti Logo
24 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
