What is a paper cutter? - Office Equipment & Supplies
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
A paper cutter is meant to cut large pieces of paper in a perfectly straight way. The tool is about 30 cm large on each side. It will have a grid drawn on the surface or a ruler along the top. On the right is a blade and it is attached to one corner. The blade lifts up to cut straight edges wherever you wish to cut. There is also a finger guard as a protective feature.
Posted on Jan 17, 2013
1600mx wont run in forward over load light comes on
Most common reason is that there is paper would around the cutters, imposing an additional load on the machine. You will need to access the cutter assembly (disconnect all power) and manually remove all of the paper that has impinged between the cutters.
If you have run any labels or paper with gummed strips through the cutters, you may wish to consider throwing this one away and buying new. (In all fairness, it "can" be cleaned, but it is going to be a real dickens of a job to do).
If you decide to keep your shredder and clean the cutter assembly, remember to oil it on a regular basis per the instruction manual.
As for me, I use Fellows shredder oil
Fellowes Shredder Oil 12 oz Bottle with Extension Nozzle 35250
and oil my machine every time I dump the cuttings. I run a bead of oil in a serpentine pattern over a sheet of paper and then just shred it. (If you have never oiled the cutters, it may be too late to do so now. Something you need to do on an on-going basis).
Jan 23, 2015 | Royal 150MX Cross-Cut Shredder
Can I sharpen the blade on my paper cutter?
You can sharpen the blade on your paper cutter but since they can be hard to sharpen you are better off leaving this task for a professional.
Sep 29, 2013 | Office Equipment & Supplies
How many pages can I cut in a paper cutter?
Depending on the cutter you can cut up to 15 pages. To be safe you might not want to try cutting more than 10 pages. Cutting too many pages can ruin the hinges of the guillotine.
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
What is a rotary paper cutter?
This is a cutter with a wheel-like blade that comes on a rail you can slide along. This lets you make cuts that are wavy or perforations. These are usually used at home becuase they are safer as the blade is wheel-like and not like a knife.
Jan 17, 2013 | Office Equipment & Supplies
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
In the paper and quality options I have only sheet or CD/DVD to select from. Roll option is not showing
The Roll Paper button cuts, feeds and returns paper to the printing position when the automatic cutter is used. When held down for three seconds, it reverses the roll paper out of the printer. The cutter can make either one cut precisely between images, two cuts with a margin between images or no cuts. The driver lets you select which method you prefer. The Utility program has an alignment option for the cutter that you should use whenever you reinstall the cutter.
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 17, 2010 | Epson Stylus Photo 1400 Printer
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Aug 02, 2009 | Royal VF1012mx Shredder
Panasonic fax
If there is a cutter it might be defective,try to off the cutter.If the is no cutter check paper sensor.clean or replace it
Mar 06, 2009 | HP FAX 1250 Fax Machine (Black)
554 people viewed this question
k24674
