Question about Dryers
My dryer is not blowing warm/hot air-just tumbling??
What could be wrong?
  • 61 Answers
IT MAY BE THE ELEMENT OR A T-STAT WAHT BRAN AND HOW OLD IT THE UNIT. 80% OF THE TIME IS THE ELEMENT
Posted on Jan 25, 2009
What are temperatures warm and hot
Air temperatures in a tumble dryer can be as hot as 175 C (347 F). That said each dryer is different and the temperatures that can vary with both manufacturer and age. If you're talking about drying clothes that say warm versus hot, they're referring to the standards of 90 C and 150 C (194 F and 302 F).
Sep 08, 2014 | Dryers
White knight tumble dryer cl847 not heating
-Possibly one of the heater element blow out.
-Timer switch assembly stuck in low position.
Good luck
Mai
Nov 21, 2013 | Dryers
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
My Frigidaire dryer makes a loud humming noise and the top and back get very hot to the touch.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
May 20, 2012 | Frigidaire FGR341AC Electric Dryer
Our tumble dryer is not blowing hot air only cold wot could the problem be ? its a creda simplicity condenser dryer - tc 22 cw
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | AEG T58840 Dryer Electric
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
Dryer not tumbling
only one thing it can be if you say burner is coming on. You have a broken belt.
Mar 26, 2009 | Dryers
Dryers Logo
105 people viewed this question
Top Dryers Experts
