Question about Fisher Paykel EcoSmart GWL15
Fisher and paykel 5.5kg smartdrive
Hi can you please help me with my machine it starts to pump water but stops after like 2 seconds the i changed the water level from auto to high and worked longer but does not move the tub at all and wont even spin just stops and keeps beeping can you please help me?
Hi not sure if this can help, however i just had a similar problem. I emptied all the water out and layed it down to look under the machine. The main power to water pump was off. Its pretty obvious if this is the problem. If not. maybe this will help someone.
Posted on Jun 24, 2009
  • Fisher Master
  • 2,651 Answers
Welll when it stops and starts beepimg the lights that are lit are describingwhatthe faultit is experiencingis, if you remove th console(2 sccrews behind the top) youll find a pretty handy trouble shootingguideto heplp you resolve your problems
Posted on Jan 25, 2009
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
How do I take apart my fisher & paykel top load washer to get to the water pump. I have an error code 37 which means blocked water pump
Hi just read your posting.Now if you look under the machine to the front right you will see a fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely.Put the machine back on its feet and select a spin cycle and push the start button.The machine should start to drain.Please reply on how you got on or if the machine still does not drain or for further assistance.Looking forward to your reply.
Oct 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Smartdrive 701 Model GW701-U
Hi mate
I had the same problem replaced the board still no go. In my case it turned out to be the drain pump. Nothing wrong with it but a small bit of grit that although difficult to see was impeding the impeller
Dec 08, 2007 | Fisher Paykel EcoSmart GWL15
Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Aug 30, 2007 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
397 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
