Panasonic sa-vk540 no sound
No sound on both speaker but good on headphone
  • 236 Answers
SOURCE: Panasonic SA- AK 133 Music system sorround system not working
this is something a tech expert on electronics can handle. even replacing parts has to be attended by a pro-technician. something is wrong with your DSP processor or system components. it could be the switch only or it could be the processor.
Posted on Mar 31, 2008
redhead7377
  • 51 Answers
SOURCE: My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
Posted on Jul 25, 2008
  • 93 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Let me show how to resolve your problem since you are not very good at this system.
A/V troubleshooting 101:
Remember the 2 speakers that you mentioned before that it worked.First,locate the one speaker output that work for you before(ex. front left)you will use this speaker output to connect each one of the speaker and leave the system on either tuner(radio with a proper station=101.3) or a dvd with sound,this way,you are troubleshooting two things for sure A. be sure all your speakers do work and B. your source is working.
After you test all the speakers with the same speaker output which had confirmed the speakers are working,that particular speaker output is working and also your source is working,send me an email and i will show the next step.
However,for any reason,if one of those speaker got no sound from the same speaker output connection,please do not waste anymore time,should take it back to the place you bought it from and get our money back and try to buy the A/V system separately(A/V receiver with speakers in one package, separate dvd player,etc.)
Cheers,
solutiondoct
Posted on Nov 06, 2008
  • 11 Answers
SOURCE: certain dvds lose the surround sound
if you are playing older or burnt dvds then chances are they were recorded using only 2 channel or stereo instead of 5.1,6.1 or 7.1 hope this is your solution
Posted on Aug 08, 2009
SOURCE: panasonic sa-pt954. no sound. display says W1
NESESITO UN ENGRANES DEL CARGA DEL DISCO
I have a panasonic home theatre system Model No SA-HT690 and want to bypass the DVD player and hook it up directly to my new Samsung TV. I want to be able use the surround sound when watching TV and u
you want to instead pass the audio from the blueray
either direct to the sa-hr690 via one of its aux inputs
or via the TV
via the TV makes sense
so find an audio out from the tv
some only have headphones
some a pair of phono plugs
so youll prob need phono to phono cables
and then your good too go
Dec 07, 2014 | Samsung Audio Players & Recorders
My receiver speakers are not working
disconnect someplace, amp problem, or speaker problem.
headphones work? then amp is probably ok.
connect another spkr to ALL terminals (1 @ a time).
then figure it out.
Sep 21, 2014 | Panasonic Wireless Digital Speaker...
How do I mute sound so as I can listen to Blue Ray through headphones
Usually, you should connecct your headphones to your TV, which will mute the internal speakers.
Sep 17, 2014 | Panasonic Sa-bt230 Blu-ray Disc Receiver
I have a Panasonic Sa-HT930 surround sound system. Plugging in headphones does not turn off the speakers, yet I can still hear sound through the headphones. How do I get the speakers to turn off??
The switch of the main speaker does not engage when you plug inn your earphone it's suppose to turn off the main speaker.you need to clean the contact of the switch of the jack.Open the cover of reciever and go to the earphone jack spray it with a contact cleaner then try again.if the same thing happen replace the jack with a new one.
May 28, 2011 | Televison & Video
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
I have an older Panasonic HDTV Viera and I am trying to hook up a Panasonic DVD/sound suround model SA-HT920 and am not having any luck getting it too work. I have the sound turned off on the tv speakers...
What does the TV really need from the receiver in all of this? Minimally, Component video for the DVD and managing the SA-HT920, not much else.
A TV is not normally an optimal source of audio.
Your broadcast TV-related sound would be higher quality and easier to obtain if you got it from the Cable or Sat box you probably have. Route ITS BEST (digital multichannel) audio directly to the SA and and its BEST (HI-DEF) VIDEO directly to the TV. You could also run vanilla analog audio to the TV so you can watch news in lo-fi audio on the TV.
The exact model of TV would be helpful to know as audio capabilities may vary.
Should you still feel the need to run TV-originated audio to the SA from the Viera through its headphone or audio output, connect that to any available analog RCA input.
Connection of a jack into the audio output will pass unmodified TV audio to the SA. That's a good thing as the REAL audio electronics needs an unmodifed source for best results.
Feb 13, 2011 | Panasonic Audio Players & Recorders
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Jun 24, 2009 | Pioneer Audio Players & Recorders
SA-HT 900 only plays music in flat surround mode no others work
I plugged some headphones in and then unplugged em and now my stereo only has abass sound . The stereo speakers seem to be broken . Have you ever heard of this problem before ?
Jan 29, 2009 | Panasonic Home Theater System System
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
 Grubhead
Grubhead
