Question about Sony KDF46E2000 46" Projection HDTV
KDF-46E2000 turns off then back on by its self
My tv has turned its self off and back on twice now. Once yesterday and once today. The power light blinks while the tv shuts down. Last night it shut down for a minute of so, today it shut down for a few seconds then back on. Lastnight the tv was on for a couple of hours and today it was on for about 30 minutes. I had not had any other problems witrh the tv, no have I ever had to chang ethe bulb. The tv was purchased in October 2006. Any help would be great. Thanks
  • 1,550 Answers
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Posted on Jan 25, 2009
Power light once, then power and OPC twice simultaneously. what would that be?
Hey Vince, not sure of your model, but this may help. Last year, my older Sony started acting up. I would hit the power button and the red light would flash, fan would come on, no picture and then would power down. I bought a replacement bulb from Amazon and that solved it! Still using it today! Hope this helps!
Dec 11, 2013 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My westinghouse "46 wont turn it the power supply and can I replace it
It sounds like the power supply is having an issue. Yes its easially replaced no special tools required just a screwdriver. You can get the power supply board from
Feb 10, 2013 | Westinghouse TX-47F430S 47 in. LCD TV
What is the code for a One for All urc-7710 remote control for an ACER tv?
I found the manual online for the URC-7710, but i do not see a code for an Acer TV.
Try a code search by following these steps:
1. Turn on TV.
2. Hold down the Magic button, the red light will blink once then twice, release the Magic button.
3. Press 991, the red light will blink twice.
4. Press power button once.
5. Aim remote at TV and press the Channel Up button repeatedly (up to 150 times) until TV turns off. Note: if you skipped the code that turned the TV off you can go back by pressing the Channel Down button once.
6. Press the Magic button to store the code for your TV set.
Well, I hope this will help.
Jun 18, 2010 | Televison & Video
TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Jun 04, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My sony tv powers its self off once i turn it on
if it turn off after sec then go to red light then it is common power supply board, but you need to check all your board fusees then look at all capacitors if it blown then replace it with the same type but when the board out the TV and be very careful for power , also get another opinion. good luck
good luck
Apr 28, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV turns off by its self
U might have sleep timer on?Push the menu to see it have 30,60,90,120.If u don't ur tv have problems.Call for warenty repair,or return it were u purchase for an exchange.
Feb 07, 2010 | Insignia IS-LCDTV32 32 in. Television
I have a sony Wega KDF 46e2000 and a couple of months a go it started going off and on by itself. And the local repair shop said we needed a new bulb it was going bad. So we bought one a month ago and I...
Three blinks is a lamp cover error. Make sure the lamp cover is back on securely and try again, there is a switch that does not allow the TV to turn on unless the lamp cover is on correctly.
If this does not work, then it means the lamp cover switch was damaged when you were putting the new bulb in and you need to get the switch repaired or get a new switch. They are two of them and cost about $15 each.
Oct 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony 46" lcd turns off by itself and will not power up again.
Sony TVs come with a one year warranty on parts and labor. Call Sony at 1-800-222-SONY They will find a local company to service this product.
These TVs have a self-diagnostic screen that a tech can access to help solve the problem. Your problem could be any number of things including the fan(s) stopping, the ballast board failing, Q-box issue or none of the above.
Feb 19, 2009 | Sony Televison & Video
Sony projection TV screen going black.
need to replace the bulb
SONY-XL-2400 replacement bulb
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Sony KDF-46E2000 LCD Projection TV
4 flashes is a bad fan, 3 flashes is lamp door switch
Jun 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF46E2000 46" Projection HDTV Logo
338 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
