Have cleared fault f21 on Bosch classixx 6 but drum will not go round,
  • Washing Mach... Master
  • 17,129 Answers
Please switch off the machine for a while and then try. If there is no result then it is possible that the drive from the controller is missing and it could be due to no output from the board. check for free movement of the motor and spindle or it can be due to failure in the board.
Posted on Jan 17, 2013
sdmc73
  • 121 Answers
SOURCE: bosch classixx 6 1200 express
go to http://www.repairclinic.com/0078.asp
Posted on Nov 29, 2008
richroth
  • 9472 Answers
SOURCE: bosch classixx 6 1400 machine
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Posted on Nov 27, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Bosch Classixx
F21 is a motor or control board fault.
This also can be caused by voltage spikes or surges...
To reset it.
Release the button.
If the problem continues then check the motor...
heatman101
Posted on Nov 29, 2010
ginko
  • 19396 Answers
SOURCE: f21 fault on Bosch Classixx
Hi.
Here the reset procedure:
  1. Ensure that there is no water in the washer.
  2. Turn the timer knob knob to OFF position.
  3. Close the washer door.
  4. Turn the timer knob to 6 o clock and wait until you see the start/pause button flashing.
  5. Press and hold SPIN button.
  6. Advance the timer knob to next part of cycle (7 o clock position).
  7. Wait 5 seconds.
  8. Leave the button.
  9. Set the timer knob to off position.
  10. Trip circuit breaker for two minutes and restart if the reset did not work.
If that does not work, then there is still a problem. F21 indicates that problem can be motor, wiring or electronic control module. Try the reset a couple of times if that does not work at first try.
Regards.
Ginko.
Posted on Dec 22, 2010
patrick_b180
SOURCE: Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Posted on Jan 22, 2011
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
I have a Bosch classixx 6 coming up with fault code f21 what can I do thanks kevin
Please check on the power , the program control panel and the motor drive- for mechanical jamming or failure of capacitor.
please check this link for help on Bosch machines.
http://www.repairclinic.com/Washing-Machine-Repair-Help
Mar 30, 2011 | Washing Machines
Motor brushes replaced but fault F21 still indicated in the display panel. How do I get the machine to work ?
F21 means motor or control board fault. Usually its the motor. If you have replaced the brushes and it doesn't work then its most likely the motor is faulty. Not a cheap fix.
Mar 08, 2011 | Bosch Classixx WFL 2066 Front Load Washer
F:21 error displayed
To reset it.
Whilst holding it, turn the knob to the 7 o'clock position.
Release the button.
When your turn it back on it should have cleared the error code.
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
To reset it.
Release the button.
Nov 27, 2010 | Bosch Washing Machines
F 21 keeps flashing and the machine is stalled and wont spin even after cleaning filter?
To reset it.
Release the button.
What is the error code f21 means on a bosh washing machine?
To reset it.
Release the button.
Nov 27, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Mar 10, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
