Dyson contrarotator drum not turning
It still makes the noise of the spin cycle but the drum does not turn
  • Washing Mach... Master
  • 17,130 Answers
It can be due to slipping within the drive., Inspect the motor and drive , remove and reset the assembly.
Posted on Jan 17, 2013
the dr
  • 447 Answers
SOURCE: Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Posted on Oct 03, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
BIKER T
  • 909 Answers
SOURCE: wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Posted on Sep 20, 2009
  • 382 Answers
SOURCE: Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Posted on Jan 07, 2010
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
The two drums seem to be fused stuck together
For past few washes I
...by tight drum halves when in contrarotation mode the motors are being overloaded a call to dyson to turn off contrarotation will stop the fault by locking the drums together as a normal washing ...
Aug 08, 2015 | Dyson Memory CRO1 Front Load Washer
Drums will not contra rotate
just read about this on another post . dyson does not service washers anymore . but 1 lady had the drums welded together by a repairman a few years back and it functioned quite well .
Jul 26, 2017 | Dyson CRO1 Front Load Washer
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
Hi just had dyson fit a new pump door lock and drawer but machine is not contrarotating now is this a fault or a dyson modifacation
Dyson engineers turn off the contrarotation on purpose to preserve the drum bearings as they aren't available anymore, its a firmware update they do automatically when they service the machine.
May 30, 2011 | Dyson Memory CRO1 Front Load Washer
Overload affected performance. Even when only got 1 item in machine. Makes lots noise when spinning and inner large plastic seal looks like something caught on it and shredded some of plastic.
this fault can be caused by the drum halves becoming tight .they move together due to limescale deposits between the drum spiders. the noise is most likely a failing drum bearing
if the plastic seal is damaged then it will need a new drum assembly
they are no longer available from dyson due to supply problems
you may be able to get another machine from ebay and fix yours using parts from each machine to make one good one
Nov 10, 2010 | Dyson CRO1 Front Load Washer
For past few washes I keep getting msg "overload has reduced performance" - this is despite differing amounts in loads. I have tried cleaning out the filter - usual problem, but this is clear.
your fault is caused by tight drum halves when in contrarotation mode the motors are being overloaded a call to dyson to turn off contrarotation will stop the fault by locking the drums together as a normal washing machine
Oct 01, 2010 | Dyson Memory CRO1 Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
How do i repair a f11 code on my dyson cro1 contrarotor
Get Dyson out, the powerboard has failed, don't be fooled into thinking replacing the fuse on the board will do the job, it doesn't, a component has failed on the PCB which has caused the fuse to blow in the first place, £95 call out i'm afraid.
Dec 30, 2009 | Dyson Flowcheck CRO1 Front Load Washer
It has been making banging noises and the drum is sqeaking.the wash programme stops mid cycle we have drained it and cleaned the filter, it is a bit better but is still not working properley.
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | AEG Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
