Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Need to remove front black plate cover on my kitchenaid
How do I remove my front cover on my kitchenaid refigerator ice/water spot? The big black plate?
  • 61 Answers
MOST OF THEM YOU PRIME A FLAT SCRUE DRIVER ON THE FRON LOWER PANE THE Y HAVE TWO SMAL SLOTH AND TWIT THE DRIVE AND THEY WILL COME OF AND DO BOUTH SIDESRT AND LF.
Posted on Jan 25, 2009
Black spots in ice for brand new installation
Crazy...
I would pat myself on the back a couple more days... and let the whole fringe get better (settle & wash out).
Just an errant thought...but if you have a water filter on your water supply I'm thinking I would rather know WHAT those spots were...
I'm thinking CHARCOAL (meaningless/harmless).
No FILTER = IRON OXIDE...
Means you have an advanced case of copper directly connected to steel pipe causing ELECTROLYSIS...
Find it fast or make sure your insurance is up to snuff.
I would capture a sample and test with a magnet
Some manufacturers suggest you toss the first load of cubes and go for it...
I think you are smart to watch what you ingest.
Carnac the Magnificent
Apr 20, 2017 | KitchenAid Architect II Series KBRS19KT...
My freezer
If you have an Ice Maker and/or Water Dispenser with this unit the red light is telling you the water filter is now time to change.
The filter is usually under the front refigerator (behing the bottom cover plate). The filter is about 8" long and 2" wide. Looks kinda like a big white hot dog bun. Remove the filter cover and spin the filter cartridge counter-clockwise and pull it out. A little water will leak but it'll close itself off as soon as it pulls out.
Reinstall the new filter the reverse sequence and run the ice water for 3 minutes or 3 to 5 gallons of water to get all the fatory carbon filter sediment flushed. The light will now turn to green.
Should be all better now.
Nov 23, 2012 | Refrigerators
Kitchenaid ice dispenser motor not running. it
remove the front cover plate. it can be popped off. you should be able to see the white gear moving. if not wiggle the white gear side to side front to back. if the motor moves you have bad contacts. these contacts are located on the underside of that gear. you can also check voltage to the motor. the inside of the front cover indicates test points for water valve motor etc. if you have power and no movement it is either the motor or contacts. if you have no power this requires further indepth investigation.
Jun 14, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Face plate around ice maker/water dispenser needs to be removed.
there are screws on the bottom of the plate. re,oive the drain pan underneith the dispenser and the screws are underneith that.
Apr 04, 2009 | KitchenAid Refrigerators
We have a KitchenAid [KSRG25FKSS03]. We turned the ice maker off for a period of time and recently turned the switch back to the on position, but now no water is flowing from the black rubber outlet into...
sounds to me that the water inlet line is frozen. If you feel of the black rubber outlet, it will probably have ice in it causing it not to pour water in thus no ice production, Remove your door that is in front of the ice maker and use a blow dryer and thaw the line. Hot water can be squirted up in the line to thaw it quicker and do a more efficient job. Once you clear the line then your no ice days should be over. It may do it again and if it does then you will need to do the same thing again adding replacement of the water inlet valve.
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
BROKEN WATER SUPPLY LINE IN FREEZER DOOR
it should just snap off and on ,,,, something they are tuff to get loose
Nov 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Not making ice
canyou acess theice amker assy itself??
can you look intor the icemaker make sure nothings blocking ice maker from turning(ice cubed jammed in )
look into the fill tube make sure itsnot frozen
thinkin htis machin hasan electronic "eye" if so htere a trouble shoooter under the kickplate explaining the mechanism
lastly theres a white cover plate on the front of the assy. remove the cover and loook at the white gear in the center of unit. look real close at the tabsholding that gear on.MOST common causeof failure is the ice torques the main gear and those tabs snap. if htats the case , replace the ice maker assy.
Mar 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Get water, but no ice
Mar 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
Jan 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
170 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
