Question about RCA F25281 TV
TV doesn't turn on with remote
The tv turns on manually, but not with the factory remote. Once on, it will not change channels, etc., with the remote. I tried a universal remote that works with the other TVs, also no luck. I bought a replacement remote from Remotes. com, also no luck. All the batteries are fresh.
  • 84 Answers
The infrared receiver on the TV is probably dead. If you're handy or know someone that is handy you could pull the TV apart and get the part number to order a new one and try replacing it to see if your remote starts to magically work again.
Posted on Jul 12, 2007
SOURCE:
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
Can this remote work with the Western Digital HD player? How would you find this code?
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Jul 17, 2009 | Philips Magnavox MRU1400 Universal remote...
I need the codes for the sylvania television as i replaced the batteries and then it stopped working my tv
controlled.
SEARCH button.
Jul 16, 2009 | Philips PM3S Remote Control
Bought universal phillips remote to replace broken one and can't find code for Daenyx
couldnt find the type of tv you have but i found something that might help you can try these
0005, 0017, 0047, 0050, 0062, 0103, 0146, 0156, 0486, 0237
or you can try doing a code search with the remote below is how to do it
controlled.
SEARCH button.
May 29, 2009 | Universal Remote Control URC-6131N Remote...
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
ZEN-SPA UNIVERSAL REMOTE CONTROL
Manually turn on the device( TV.,VCR,etc) to be controlled.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the code search button.
Press and quicly release the desired mode button(TV,VCR,etc).The red indicator blinks off once.
Press the CHaNNEL UP button repeteadly(up to 300 times) until the device to be controlled Changes Channel.The red indicator blinks off with each button press.If you overshoot the code required,press Channel Down button to backtrack through the library until the device changes channel.
May 29, 2008 | Zenith DBZN-311 Remote Control
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Televison & Video Logo
162 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
