Question about Kitchen Ranges
How do i remove the elements from Nobel NF60 SS/1 Stove
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have Nobel stove approx
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Dec 13, 2010
The door on my Nobel model: Nr.: NF 60 SS/1 will not seal when closed.
Oven doors can warp over time. Also, if the door has a heat shield that covers the window and locks the door during self-cleaning it can become misaligned and prevent the door from closing properly. Minor alignment and adjustment can be done by loosening the screws on the hinges and taking advantage of the slots provided for positioning the door before re-tightening the screws however if the door is warped too much you may not have enough adjustment travel available to properly re-align the door. The metal gasket around the door may also have become damaged and is preventing a proper seal and you might be able to locate replacement gaskets at an appliance parts house.
Nov 19, 2014 | Ovens
I hit 350 and start on my range and sparks flew out of both sides and now the oven does not work. The stove works but not the oven. can you tell me how to fix this.
It sounds as if the bake element has failed. They cost around 8 to 20 dollars. You will need to unplug the stove first. (Shutting off the stove breaker is good to do before unplugging the stove as an added precaution). On the back of the stove there is a metal
cover with a couple of 1/4 inch hex screws. remove this cover and unplug the bake
element. Then remove the two hex screws inside the oven and slide out the bake element. The model number is located below the oven door behind the drawer to
purchase a replacement. Hope this helps.
Jul 13, 2011 | Frigidaire Kitchen Ranges
Hi, I have a Nobel FSE90 free standing oven which needs a new bottom element. Any ideas where I might purchase one? cheers, Shelley
Hi Shelley,
I'm presuming you are in Australia (From what I can tell this is an Australian make??)
If so then you can contact Nobel's service and spare parts on:
1300 855217 or mail them on spares@nobel.com.au
Jul 08, 2011 | Microwave Ovens
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
I need a replacement element (8 inch) for my Kelvinator range (model no. KRS J3L-1)
Hi, W/D here.
Here's the easiest way that I know of to repair your stove:
Remove your element. Most can be removed by lifting the element on the side away from where the leads disappear under the stove top, and then pulling it out of the plug-in socket.
Take the element with you to one of the larger hardware stores, and locate the elements that have your style of terminals. The elements are generic; that's why you needed your old one. I have replaced dozens of elements and have found the generics to be every bit as good as one ordered, and cheaper, too!
Best regards, --W/D--
Jan 31, 2011 | Microwave Ovens
I have Nobel stove approx 18 months old. 5 gas burner with electric stove. Modle FSE 9013M-1 One of teh knobs has broken. Where can I get a relacement?
How to Buy
heatman101
Dec 12, 2010 | Ovens
Bake element got white hot and sparked
your element burnt through it will need to be replaced
Apr 02, 2009 | Electrolux Kitchen Ranges
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
