Question about Saeco Royal Exclusive 30153 Espresso Machine
System 2 The display screen says "Please activate system 2." Before this it says "Energy Saving Mode." I press the button to sidpense coffee and after a few tries it finally works.
5 Suggested Answers
mirran
  • 515 Answers
SOURCE: Takes forever to warm up
Have you decalcifyd the machine?
If there is calcium in the boiler then it takes long time to warm up and if you much calcium in it then it never be warm.
I think you have to replace the boiler on that machine:-(
Posted on Jul 11, 2008
  • 2039 Answers
SOURCE: saeco magic
look like or brew unit is block if you didnt change the kind of cooffee or play with the grinder to fine of a grind normally the grinder should be at 5 or 6 the brew unit the top part with side pipe remove the 2 screw be carefull there a little spring and rubber seal and a little ball of glass remove notice how it goes so youll be able to put back after removing those part clean the hole all the way to the to the filter it should do the trick let me now how it turn out thanks pierre
Posted on Aug 03, 2009
  • 1089 Answers
SOURCE: Saeco Royal Professional is stuck on "Ventilate"
Hi
There are possibly 2 things that it could be.
1. Check that the tip of the wand is not plugged.
2. Your solenoid valve that controls the water is bad or stuck. That means a trip to the service center.
Posted on Apr 19, 2010
bbl242003
  • 1637 Answers
SOURCE: my machine always says fill watertank even when
Ok, I will help,
Please respond to this using COMMENT or REPLY
Has anyone tried to wash this in a dishwasher in the past?
Posted on Jan 13, 2011
Cannot get steam to come out of my delonghi prima donna XS coffee machine
Could not find why but maybe if you go back over the scaling procedure and steam procedure there might be something you missed.
Please note! If "Energy saving" is active, you may have to wait a few seconds before hot water and steam are delivered.
Steam delivery 1. Make sure the hot water spout is attached correctly (fig. 7). 2. Fill a container with the liquid to be heated/frothed and immerse the spout/cappuccino maker (D5) in the liquid. 3. Press the steam ( ) button. After a few seconds, the steam to heat the liquid comes out of the cappuccino maker and "STEAM" is displayed. 4. When the required temperature is obtained, interrupt steam delivery by pressing the steam ( ) button again. (You should not discharge steam for more than 3 minutes at a time).
http://www.delonghi.com/Global/InstructionManuals/EN/EN-PrimaDonna-ETAM36365M-im.pdf
customer support
Customer Support
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
How do I disable power save mode
Press the Power key > Activate power saving. To deactivate power saving mode, press the Power key > Deactivate power saving.
When activated, the power saving mode turns off some functions automatically. Radio configuration in power saving mode include the cellular radio (it is set to 2G/GSM only mode), the Bluetooth radio (it is turned off) and the Wi-Fi/WLAN radio (scanning for new networks in turned off but existing networks keep functioning). The power saving mode also reduces display power consumption by minimizingscreen brightness and by turning off touch screen feedback and theme effects. In addition the vibra alerts are turned off in a power saving mode. Hope that helps Anomy.
Mar 16, 2015 | Nokia N8
Samsung rs263tdbp and demo/cool off mode will not turn off
from the manuals Page 1. Activating/Deactivating Cooling Off Mode When the refrigerator is in Cooling Off Mode (aka Demo Mode) the display will read "OF OF, O FF, or OFF OFF." Cooling Off Mode prevents the unit from cooling. It is used by retailers to display units without wasting energy.
Note: Models without digital displays will display scrolling lines when the unit is in Cooling Off Mode.
Tip: If your display panel has buttons that have to be pushed in to perform any functions, replace the word "Touch" with "Push" or "Press" in the following steps.
  1. Touch and hold the top two buttons on the left side of the display panel.
  2. Important: You must touch the 2 buttons at the exact same time. Not doing so will result in an unsuccessful attempt to activate/deactivate Cooling Off Mode.
    [img src="http://www.samsung.com/us/system/support/content/2011/04/25/h5408/Demo_Mode_250_Pix_1.jpg" align="bottom" border="0" height="127" width="250">
    Notes:
    • As long as the display panel is located on the exterior of the left door of your refrigerator you will use the top two buttons on the left side of the display panel to activate/deactivate Cooling Off Mode.
    • If your display panel is located inside of the unit along the door frame you will need to locate the words "Cooling Off (Hold 3 sec)" printed on the panel. The Power Freeze and Freezer buttons are the two buttons used for Cooling Off mode on these models.
    • Wi-Fi Touchscreen displays on RF4289* and RSG309* are exceptions to this article. Cooling Off Mode is activated/deactivated through the settings menu.
Apr 01, 2014 | Samsung RS263TDBP Side by Side...
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
Hi
Apr 17, 2010 | Saeco Royal Professional Espresso Machine
The pc entering in pwoer saving mode and
  1. Start or restart your computer.
  2. Press the F10 key when the F10=Setup message is displayed.
  3. Select the appropriate Language option.
  4. Select the Power menu.
  5. Select (if not already selected) the Energy Saver item.
  6. Press the Enter key.
  7. Select Advanced .
  8. Press F10 to save the change.
  9. Select Power > Timeouts > Hard Drive Timeout > Never .
  10. Press F10 to save the change.
  11. Select the Power > Energy Saver .
  12. Press the Enter key.
  13. Restore the desired Energy Saver Mode (Disable or Minimal).
  14. Press F10 to save the change.
  15. Select File > Save Changes and Exit .
Feb 03, 2010 | HP Compaq d530 PC Desktop
My screen acts as if it's on energy-saving-mode but doesnt activate...
Check and reset the Screen Saver to the settings you want, even if its set properly. Did this work?
If not, reset the monitor to factory defaults to flush its memory.
If that doesn't work unplug the monitor for a minute and replug.
Sep 02, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
How di I get my K850i to show the time in screen saver mode
Press the volume button on the side of the phone to display a screen similar to previous Sony Ericsson Cybershot phones during standby mode. It will display the time and a message icon. This is probably an energy saving feature when the screen goes black in standby mode, but you must press the volume button to get to that screen.
Feb 25, 2008 | Cell Phones
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Saeco Royal Exclusive 30153 Espresso Machine Logo
233 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
