Question about Delstar DS 917 Digital Media Player
How do you upgrade your device - Delstar DS 917 Digital Media Player
  • Anonymous Mar 19, 2009
    my sandisk portable storge chip needs to be upgraded so i wont get the synchronize message went i try to play the music on it
Reboot after 10 seconds.
You have accomplished what is known as "bricking" your device. If anything interrupts a firmware update, in most cases the equipment will be unable to recover from it. It will require factory servicing to reestablish the firmware. It is usually cheaper to buy a new device. Remember this about firmware upgrades - just because one is available does not mean you should upgrade. Many devices will work forever without them. Unless you are in a situation where changing requirements of your equipment and/or providers means an upgrade MUST be performed, the best rule is "if it isn't broken, don't fix it!"
May 17, 2016 | Computers & Internet
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
How to by pass 0.7 iOS software upgrade as my phone version is only a 6.1.6
You only can upgrade to the newest version of software available, for your device. Older iOS devices can't always upgrade to iOS 8. On the Apple site you can find what iOS is the latest for your device.
For upgrading, you best use iTunes on your computer (Both MAC and Windows). Upgrade via the air, needs more than 5 Gbyte of free space on the device. (for downloading and extracting and swap space in the device)
Oct 21, 2014 | Apple iPhone 3G
How do I upgrade iPad 2 to ios 6?
there are two ways to upgrade the iOS version of your iPad
- via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
upgrade-ipad-2-ios-6-ziidwqfjzh12fiagolk42ia4-3-0.jpg upgrade-ipad-2-ios-6-ziidwqfjzh12fiagolk42ia4-3-2.jpg upgrade-ipad-2-ios-6-ziidwqfjzh12fiagolk42ia4-3-5.jpg
Jul 30, 2014 | Apple iPad Tablets & eReaders
How do i download samsung galaxy s gt-i9000 firmware
Option 1. OTA(over the air) without cable
Go to Settings > (More) > About device > Software update > update
Before upgrade by OTA,
-Recommend using a proper Wi-Fi network to avoid abnormal carrier data fee.
-Make sure to charge the battery (more than 50% capacity) and to have the enough device memory. (at least 1GB )
-Do not remove the battery during upgrade.
-Do not use the rooted device.
Option 2. Computer with a cable
Install the 'Kies' and run it after connecting your phone. Simply follow the instructions shown in the 'Kies' software upgrade menu.
Go to Kies 4
Option 3. Visiting the shops
Samsung Experience Shops(SES) are supporting the Smart Service* with software upgrade. Ask software upgrade service to Samsung experience Consultant at Samsung Experience Shop; you can enjoy the Samsung device, its accessories and contents freely during the upgrade time.
* Smart Service may not be available in some shops under space condition.
Jun 24, 2014 | Samsung Galaxy S GTI9000 Smartphone
Ios 5 download
- depends on the model of your iPad:
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer.
- but this model supports only iOS 5
- NO iOS 6/7/8
for all other models:
There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
ios-5-download-ziidwqfjzh12fiagolk42ia4-3-0_0.jpg ios-5-download-ziidwqfjzh12fiagolk42ia4-3-2_0.jpg ios-5-download-ziidwqfjzh12fiagolk42ia4-3-5_0.jpg
Feb 06, 2014 | Apple iPad Tablets & eReaders
Why wont Mac drive boot after upgrading itunes
Did you upgrade coincidentally the PC upgrade or the Mac upgrade check that out to make sure? Remove the IPod or the device before starting your computer again then plug in the device. It may also be upgrading and you did not complete the upgrade. Could this be possible if so re-download I Tunes again completely be sure to remove I Tunes first then go and download I Tunes again. This may solve the matter. I hope this gave you some relief John
Apr 21, 2012 | Dell Inspiron Mini 10 N450
Befsr41 v4.2 power led's blinking.. already tried to hard reset but it's still blinking.. it's happen after i upgrade firmware to the newest (2.00.4 build 5) (the fw upgrade message is succesfully upgraded...
Hi there. I have this same device. I tried everything that can be tried, including replacing the device. Replacing the device worked.
This solution may work for you too.
Nov 13, 2009 | Linksys EtherFast Cable/DSL Router
My mp3, file system error
you may have to upgrade your mp3 device software.
  1. you can do this by installing the software from the installation cd in the computer
  2. connect your device to the computer
  3. there will be a software installed in the computer called firmware manager, double click on it .
  4. after you have entered the pop-up window there will be an option to upgrade.
  5. click on it to reinstall and upgrade your device software.
but doing this will erase all the details in the device and all the settings. so make a backup of the songs and any other details in the device.
the solution which i have given is for a philips mp3 player. if yours is a different one please refer to your instruction manual for the firmware upgrade!!
Sep 10, 2009 | Audio Players & Recorders
Upgrades
Can you please assist me with a site to download upgrades for my gps Audiovox NVX227SA.
The Maps loaded on the device are old.
Aug 19, 2008 | Audiovox NVX226 GPS Receiver
Delstar DS 917 Digital Media Player Logo
66 people viewed this question
Top Delstar Audio Players & Recorders Experts
Damen Wong
Damen Wong
Lori
Level 1 Expert
Harrie
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
