Question about Home
Where can I find large valet case? - Home
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
You should try online, googling Valet Case. however if you just need a case I would loose the word Valet as you wont find as many results.
Posted on Jan 17, 2013
Valet key is green. Does that mean the emblem or the case. I have black cases with green emblem one is silver the other is gold?
the valet key has a green housing and should only fit the door lock and ignition lock, not the boot or glove box.
Jun 08, 2015 | 2003 Jaguar Xkr
How to program a ezsdei474 remote to a viper 130xv
Open door, turn on ignition. Press and release valet switch then, press and hold valet switch. Press lock button on remote. Release valet switch, turn off ignition. Test.
Feb 08, 2014 | 473v Viper Remote Case Three Button
Zte valet caller can't hear me but I can hear them
great. a friends having the same issue. wish there was an answer to this question. So far we've turned the phone on and off, removed the battery, removed the case, checked the volume, checked the microphone for debris, and went through the settings menu. Whats up with the Valet?
Dec 25, 2013 | Tracfone Wireless ZTE Valet
My remote stater doesnt work!!
Check to make sure the unit installed is not in VALET MODE, then check the battery in your keyless remote, most of the time that battery has gone dead. it should snap apart or unscrew and will require a large watch type battery in most cases
Feb 09, 2013 | Chevrolet Impala Cars & Trucks
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Where did they put the valet/program buttom on my 2004 Rendezvous?
This is somebody else's so;ution, but it might give you an idea on where to start. I always thought the valet switch was just a key that you gave to the valet. But inn this case out of my legue, my old dodge pickup doesn't hAVE AND MOST LIKELY NEVER WILL HAVE A VALET SWITCH. So check this so;ution oout and see if it gets you going in the right direction.
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings- Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
  • By avatar11.jpgBraunson Y309 days ago
    Braunson Y Level 2
    • 467 Solutions
    • 282 Score
Dec 19, 2011 | Viper Security and Remote Start System...
What dose the valet button do and where is it situatedin the car
The valet button is to the right of the steering column and is quite a large button and has the words 'VALET' clearly written on it. I think it allows you to lock valuables in the glove box but allow a Valet or Service engineer to drive the car - they will not be able to get into the glove box. I sdon't have the XK8 owner's handbook, and so I am guessing about the function of the Valet button, but that is what a similar device does on my Merc.
Aug 25, 2011 | 1999 Jaguar XK8
Alarm does not beep when locking and unlocking
take it out of valet, open the door push the valet switch one time, turn the key off and hit the valet button again, problem solved.
Nov 05, 2010 | 473v Viper Remote Case Three Button
I replaced my battery in one of my remotes the system doesn't recongize the remote? Crime guard 328
reprogram remote. turn key to position, push valet button 5 times and then push the lock button on remote
Feb 01, 2010 | 119 Remote Replacement - i2/i3/i4 Series...
Replace battery in a valet remote start
have to do it within 2 mins....use a knife and split the case open the rest will be simple aftre that
Jan 13, 2009 | Directed Dei Valet 561r Remote...
Home Logo
368 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
