Question about Onkyo TX-DS575 Receiver
Bose Cinemate Subwoofer Output
Hi, I just set-up the system. I am pleased with the clarity of the satellites. However, the subwoofer output is anemic at best. I would appreciate any ideas. Thanks.
    Problem Solver:
  • 15 Answers
Hi.
have you try to increase the output of the amplifier to the subwoofer??
did u select satellites as small option?? otherwise the sub will sound to low!!
and remember to have the more of the subwoofer, the place is vital!!
Good Luck!!
Posted on Jan 25, 2009
No volume cinemate gs seris ii
OK, so your Bose remote is set up for your TV. That's good. You still have to connect some kind of audio output from the TV and connect it to one of the inputs on the Bose. Then you must select the input button on the Bose remote that you connected the TV to. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 10, 2013 | Bose CineMate GS Series II Speaker System
No sound using optical out on sony bravia xbr
Optical Output is not generally used for a subwoofer output, nor is it used as a subwoofer input. Please check the type of connection again to be sure. Both methods are for digital use, however, the Optical output uses an LED for digital communications at the receiver, as well as an Optical transistor to receive this input at the subwoofer. Optical connections willing have a blicking light at the end of the cable that goes to the subwoofer, coaxial(RCA) connections will not flash. For more information, please contact me at my website audioserviceclinic.com. Thank you.
Sep 23, 2013 | Bose Lifestyle 28 System
Hi, I have a Cinemate Bose Speaker Series II System and I would like to know if I could connect Stereo Jacks from the Bose Module to a Stereo Receiver without damaging the speakers or subwoofer, and if...
That would depend on the unnamed receiver.
Most receivers have standard analog stereo outputs labeled Tape Out or something similar. You can use them as sources for stereo analog material but their outputs are not variable or under any receiver sound controls so the Bose volume will need to be adjusted. If using a Tape Output, do not select the output for listening on the receiver. THAT would disconnect the other source you're listening to.
If your receiver has a Pre-Out for the desired channels, they ARE under internal sound controls so you could set and forget the Bose volume.
Apr 14, 2011 | Bose Cinemate Digital Home Theater System...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
Hello ! I'm not sure how to connect my kef psw 2500 sub to my yamaha amp. I've got a subwoofer out on my amp but there's 4 inputs on the sub and I don't no which one to use ! Please help as getting...
Just for clarity, I need to explain what the four inputs are on the KEF subwoofer. There is a left and right RCA input which is the input signal to the subwoofer and there is a left and right RCA output which is the High Pass output from the subwoofer.
On the back of the Yamaha receiver, you said you have a subwoofer output. This output is most likely the mono subwoofer part of the home theater system and can be used if you like. The left right signal input into the KEF is summed into mono so if you only connect one channel you will basically reduce the signal level by 1/2 (-3dB) but it will work fine.
Alternatively, if your Yamaha receiver has monitor out and monitor in, you can run the monitor output signals to the subwoofer and you can then run the high pass outputs from the subwoofer back to the monitor in. This will give you the subwoofer and provide a smoother signal matching with your audio system.
It is not always easy to connect the subwoofer up to an integrated receiver/home cinema system using the high pass channels of the subwoofer as you don't always have access to the analog output and input of the front channels. In this case, just use the Subwoofer output or just the monitor out only.
I hope this solution is helpful.
Dec 03, 2010 | KEF Audio PSW 2500 Subwoofer
Trying to connect to LG 60 inch plasma. no output
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Dec 26, 2009 | Bose Cinemate Digital Home Theater System...
How do i hook my bose cinemate system to my lg tv?
If you lg has Optical Output, Which is a 20.00 Toslink Cable, You hook the cord into the Tv using the Optical Output Port then run to the optical in or DIGITAL In on the Cinemate, If you don't have the option to run optical Check for Red and White Monitor Out from the TV and Run into Red and White on the Cinemate.
Dec 15, 2009 | Bose Cinemate Digital Home Theater System...
How to hook up to hdtv
You should be able to connect the bose directly from the cable box. You also can connect from the audio output of the TV itself providing it has an audio output.If all eslse fails you can use the headphone output from the TV to the input of the Bose system
Nov 28, 2009 | Bose Cinemate Digital Home Theater System...
Cinemate won't play through LG 50 Plasma 750p
use the audio input of your cinemate to connect into tv audio out using rca cable. please check your tv if it has jack for audio out.
Mar 28, 2009 | Bose Cinemate Digital Home Theater System...
No audio out connecter on back of Phillips 52 in TV
Hi and welcome to FixYa,
Almost all (European) Philips have a SCART type connector as shown below.
With the use of a SCART Adapter (below), the outputs are available as Audio L/R & Composite Video and S-Video either as output or input.
Good luck and thank you for using FixYa.
Feb 09, 2009 | Bose Cinemate Digital Home Theater System...
Onkyo TX-DS575 Receiver Logo
243 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
