Question about Canon PowerShot A650 IS Digital Camera
Canon A650is lens error
Lens cover will not open and lens will not extend when power on.
Tried two sets of new batteries.
Tried remove and reset memory stick.
Tried "gently" bumping camera body.
What do you think I should do?
Thanks in advance.
If you have a older Canon Camera
and send it to Canon to be repired
It will be sent to:
United Radio Repair
5703 Enterprise Pkwy
East Syracuse, NY.
Tel: 315-446-5570
Skip Canon and deal directly with them.
I have had good luck with this company in the past.
Posted on Jul 09, 2012
  • Mike Collins Jul 09, 2012
    It will be sent to:
    United Radio Repair
    East Syracuse, NY.
    Tel: 315-446-5570
    Master:
  • 505 Answers
Since you have already tried the basic steps just try to apply some pressure and check. If the lens still do not open up you need to get it repaired from a tech shop.
Thanks
Posted on Jan 25, 2009
Hi This morning my canon sx200 is dropped when it was open and i found little bent in lens cover. I could able to take picture also at that instance. But when i tried to turn off, lens could not able to...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 22, 2011 | Canon PowerShot SX 200 IS Digital Camera
Lens error - restart camera how to fix it?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 28, 2010 | Canon PowerShot A470 Digital Camera
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
When turning on the camera it shows 'Lens error restart camera'
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 10, 2009 | Canon PowerShot A470 Digital Camera
Canon lens cover won't open
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
May 28, 2009 | Canon PowerShot SD870 IS Digital Camera
Jan 28, 2009 | Canon PowerShot SD600 Digital Camera
Lense won't retract on Canon Powershot SD630
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. You're also more likely to be successful trying these than going inside the camera:
Finally, if you absolutely must open the camera, here's a couple guides to replacing the camera's LCD that may help:
http://cannonlcdrepair.blogspot.com/
http://digitalcamerarepair.googlepages.com/sd600
Jan 04, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error on Cannon Powershot SD600
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
SD700 IS lens error
Before opening the camera, recommend trying the following first to try to correct it. The listed fixes only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 31, 2008 | Canon IXUS V2 Digital Camera
Canon PowerShot A650 IS Digital Camera Logo
208 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
