Question about Philips DECT 2252S Cordless Phone
Dect225 I have locked my handset and can't unlock it. Help!
  • brummybird Dec 04, 2007
    My handset has locked by itself. The key pad doesnt work so we cant ring out or answer calls. I have lost the manual so need help please.
  • 71 Answers
Press "lock" key for several seconds. Untill you hear the confirmation tone.
Posted on Jan 21, 2009
  • Richard Liao
    Richard Liao Jan 21, 2009
    Brummybird, you can try to disassembly the battery pack, and power off and on ,to try again.
    If it still doesn't work, check if the keyboard is blocked somehow. try to move it or shake it .
    If it still doesn't work, use screwdriver , open the handset to have a look, Maybe need use alcohol to clean the key .
I have a Philips DECT 525 twin phone and I can't get a ring tone and when I ring a number there is no response, please help.
Posted on Aug 29, 2009
SOURCE:
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
My screen wants me to enter a password but any password that i entered doesnt work althout evry reset that i try doesent work what should i do?
Make sure you have the correct passwords for the various 'lock':
  • Phone/Handset Lock
  • Sim Lock
In either case, a handset reset will not unlock your phone!
If it is a Phone/Handset Lock, then Acer / manufacturer Help Desk maybe able to assist you. A third party mobile phone unlocker may also be able to 'master' reset your handset (use Google to search).
If it is a SIm Lock, a PUK code may be required (you will be prompted for this) and any excess attempt will permanently disable your Sim card: you can request your PUK code from your mobile service provider help desk.
Sep 18, 2011 | Acer F900 Quadband 3G HSDPA GPS Unlocked...
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
Jun 07, 2011 | Nokia E63 Cell Phone
HANDSET LOCKED
To Unlock it ...You can get the Unlock code here http://www.mobileunlocksolutions.com/motorola-motokrzr-k1/rs1wp9/
and Unlock the Mobile..........
Jun 08, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
I need unblocked, you could help me...
Could you please clarify if you mean unblocked or unlocked? If the handset is blocked, barred or blacklisted you would need to contact the originating network of the phone to request the handset be unblocked. There is no other legal way you can unblock a mobile phone.
If the handset is simply network locked, you would contact your network service provider and request the unlock code (there may be a charge for this) or visit an online unlock code supplier (link below). There is no free solution for unlocking the Nokia 6300.
Nokia Unlock Codes
May 19, 2010 | Nokia 6300 Cellular Phone
Unlocking the nokia 6233
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Special Code/Service Provider Lock Code:
This code is required to allow a phone locked to a particular network's SIM cards to be used with a SIM card from another network. Orange and T-mobile lock handsets in this way, though O2 and Vodafone are beginning to lock PAYG and WAP handsets. The unlock code varies from individual handset to handset.
Which is the one that you want?
Blacklisting:
This is not a security code, but it works like one! To help combat mobile phone thefts, the networks share a database of the IMEI (International Mobile Equipment Identity) of mobile phones that have been reported stolen. Once a phone is on this list, it will not be allowed to use any of the networks.
This can be a risk if you buy a second-hand phone, because if it has been stolen, or if an unscrupulous seller makes an insurance claim after selling, the phone you bought in good faith may be permanently disabled.
Be very careful to check the source of a second-hand phone!
"Confucius he say: Nail on board is not good as screw on bench."
Apr 15, 2008 | Nokia 6233 Cellular Phone
N70 phone lock...please help
just take your handset to the technician near by and get it unlocked ...
the technicians will be having the special DKU series cable which is connected to the pc and the software offers to unlock the phone ,flash ,to reset the codes to the codes to the default codes etc ...
this DKU series cable are compatible for the certain model ...
there will be different types of DKU cables available ...
if you have this DKU series cable you can only unlock it there is no need to go to the technician ...
if you dont have then
just visit to the technician ..
if unlocking is not possible then just get flashed your handset...
any doubts reply me
i am always here to assist you..
thank you
bye ...
Apr 10, 2008 | Nokia N70 Cellular Phone
Forget my lock code for N73 music edition
please help me.,,.,
i forgot the lock code of my cp.,.,
how can i get my master unlock code?
plz help.,,.,
Mar 13, 2008 | Nokia N73 Cellular Phone
Unlock LG Chocolate
PHONE UNLOCK PROCEDURE
Please follow the instructions below to unlock your LG KG800 handset:
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Enter 2945#*7101# while in standby mode
4. Select Menu, then go to Settings > Security > SIM Lock > Network
5. Select Deactivate and enter the 8-digit NCK unlocking code provide for your handset..
6. The handset will be unlocked automatically and will display "Done".
Mar 02, 2008 | LG KG800 Cellular Phone
Philips DECT 2252S Cordless Phone Logo
533 people viewed this question
Top Philips Lands Phones Experts
Ekse
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
