Question about Master Lock 5400d: Portable Select Access Key Storage Lock
I want to change my Master Lock combination
I have tried many websites asking how I can change my combination but nothing worked. I want to change it so it would be easier for me to have the same combination as my locker at school.
Open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Posted on Jun 24, 2009
  • 10,865 Answers
Some masterlock combination locks are changeable and some are not. Do you know which model you have? If so, you can call your local masterlock distributor, such as a hardware store and ask. They should be able to help you. good luck
Posted on Jan 25, 2009
How to set combination for my TSA002 SERIES MASTERLOCK
Posted on Dec 20, 2009
  • saul rodriguez-torres Dec 18, 2011
    boooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
I tried ALL of the websights i can find but NOTHING help at all so just buy a new lock people
Posted on Dec 18, 2011
I cannot open my safe I had turned the wrong combination and then tried to open with the correct combination but have tried many times with no success
You have either damaged the lock, or changed it to something other than the correct combination. Try settings, just slightly different to the "correct" one. If nothing else works you will need to call somebody to fix the lock.
Dec 29, 2017 | The Home Security
How do I get unlimited coins on my pixel gun 3d
I have to work to earn my coins. I did so for 47 years already. So if you find a way to get coins for free, please tell me, so I can stop working.
Jan 05, 2015 | Computers & Internet
1998 DODGE CARAVAN 2.4 4CYL . TO CHANGE THE EVAPORATOR CORE , DO I HAVEE TO REMOVE THE COMPLETE DASH .
Yes, the dash will have to be removed as there are three interior nut/bolt combinations that will have to be removed that cannot be accessed under the hood.
Make sure to check everywhere for leaks and not just jump to the evaporator core. It's a lot easier to replace a hose than it is to replace the evap core.
May 28, 2011 | Computers & Internet
Dvd does not work anymore
Ask if DVD has changed political alliance to Democrat...
Just kidding
If the DVD used to work, please try again with last DVD you knew to work.
Check if setting were changed in menu options.
Check manufacturer for replacements (note, that you can often use a generic DVD player
Sep 27, 2010 | Philips 17MD255V Combo
Resetting a Scorpion alarm fob
not sure if this is it for your particualar model but this is how it is for all my cars take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again hope this helps dont hesitate to ask if you have anymore problems or if this does not work pleases tell me and ill see what i can find
Jan 05, 2009 | Honda/acura Immobilizer Bypass for Remote...
Combination changed
Contact Samsonite and ask if there is a default code. If not, and the kid can not open it, you have a lot of combinations to try > SORRY!
Did you try to pick/pop the latch with a bobby pin or paper clip?
Jun 04, 2008 | Samsonite Tripod
Aspire 1690 wireless connection problems
what sort of wireless card does that carry. Sometimes it's easier to get the right drivers from that website, instead of through the OEM computer folks.
Mar 09, 2008 | Acer Aspire 1690 Notebook
Security code
very easy the default security code is 1234 or 12345 you will thank me on this..
Feb 08, 2008 | LG P7200 Cellular Phone
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
7,254 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
