Question about Weber Genesis Silver B Grill
Can I convert weber q from butane to LPG (Australian)
    Novelist:
  • 200 Answers
From propane to LPG... Yes! It is nothing more than a conversion kit. But if you actually mean butane, then I am not sure.
Posted on Jan 21, 2013
3 Suggested Answers
SOURCE: Weber EP-310 Gas Issues
Hi Amir
Did you ever get an answer to your issue? I am also curious if I can bring my Weber to Israel...
Posted on Feb 18, 2010
  • 4736 Answers
SOURCE: Hello. I have Weber Summit
Ronni, unfortunately none of the Weber grills are approved for conversion from one type of gas to another. Each grill is tested and approved for it's specific gas type. Based on that, converting it, places all the liability on you, if something should go wrong. In addition, it takes more than just the burner orifices to convert a grill safely. With any gas appliance, always err on the side of caution and safety.
Thanks for choosing FixYa.
Posted on Sep 12, 2011
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
Are Propane LPG fryers compatible with Butane LpG
Talk to the manufacturer or check your owners manual. The jets in the burner must be slightly smaller for butane. The flame will burn yellow with black soot/smoke if you don't change them.
Jul 24, 2014 | Pitco Frialator Kitchen Appliances -...
Convert new Weber gas grill from natural gas to LPG. Can it be done safely by a gas pro? Who can provide needed parts, i.e. gas injectors?
Click on the Weber link below for customer support and the nearest location that can service your grill. http://support.weber.com/
Oct 15, 2013 | Weber Grilling
Conversion
Click on the Weber link below for customer support and the nearest location that can service your grill. http://support.weber.com/ Weber com Parts Support
Hello. I have Weber Summit 670 NG and I would like to convert it to LPG. I was told that it can be solved if I replace the NG Orifice with LPG Orifice. Is that true ? Where can I buy the LPG Orifice...
Sep 12, 2011 | Weber Summit S-670 Gas Grill
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Running on lpg then stop turn engine off then start engine and drive 20 metres and engine stalls! switch over to petrol and runs ok switch back to lpg and stalls
check that your cooling system if full of coolant. the coolant that keeps the engine cool actually keeps the gas converter from freezing. alternatively is it hard to start of a morning when cold, if so could be butane wax build up from the gas, in the convertor.
Jun 22, 2008 | 2007 Toyota Land Cruiser
Weber Genesis Silver B Grill Logo
277 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
