Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
I have a combo washer/dryer whirlpool machine, hot water come out instead of cold water does the timer faulty?
  • Whirlpool Master
  • 17,130 Answers
Check and see the program that is selected. now check the inline water flow of the cold water and also the hot water.IF there is no cold water in the cycle there is no output to the inlet valve from the controller, check voltage to the valve, if present the valve is faulty. If not the timer is faulty.
Posted on Jan 17, 2013
  • Kenneth Koellner
    Kenneth Koellner Mar 20, 2014
    I did this and have water coming out of the hose.. My machine runs ,the tub spins , but I get no water in the
  • Kenneth Koellner
    washer . any suggestions .. Fern
  • 121 Answers
SOURCE: Washer/Dryer
it depends if you have a combie boiler if not should be cool but if so would recomend a screw on tap connector from any good hardware store for your cold pipe
Posted on Mar 03, 2008
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
onthejob5130
  • 640 Answers
SOURCE: water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Posted on Jan 17, 2009
  • 378 Answers
SOURCE: my whirlpool front load washing machine accept hot
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Posted on Apr 03, 2009
  • 2468 Answers
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
Posted on May 10, 2010
Whirlpool washer letting both cold and hot water in when I only ask for cold water...
The water valve is working. It only does as told. Faulty water temp switch or yank out the small board and clean the terminals then re insert it and see if maybe corrosion was all that it was. That is what I would try if it was mine.
Dec 22, 2016 | Whirlpool Washing Machines
Machine will wash on hot only will not on cold or will not fill with cold at all
This is an indication that the solenoid on the cold water valve is bad. Or the cold water valve is plugged. If you can get to the valves, use a meter to check the solenoid OR the power to the solenoid. That will tell you if it is bad. If you dont have a meter, switch the wires from one solenoid to the other and see if it fills
Feb 01, 2013 | Whirlpool Clothes Washer Heavy Duty...
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
3397244 J washer: Dryer works but the solenoid is
mary . if the valve is bad / will have to be replaced . generaly if it won't fill on hot it will on cold as both don't go bad same time . lid sw only controls spin / timer could be problem . ck that water is on and if in a cold area its not frozen . hope this will help
Dec 07, 2009 | Whirlpool LTE6234D Top Load Stacked...
Maytag top load washer won''t fill with hot or cold water.
solenid valve
may be faulty.
to test disconect from the cold side and atch to the hot side,
the solenid valve is an electronic valve that switched the water on and off its usally atched inside of the back of the machine where the hose attaches to.
http://en.wikipedia.org/wiki/Solenoid_valve
May 03, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
