Question about Samsung Chromebook Series 5 3g Arctic White Atom N570 Ssd Wifi 12.1" Notebook
Samsung Chromebook Series 5 Screen Replacement
Unlike the Chromebook Series 3, the bezel around the screen on my Chromebook 500c cannot be fully removed because of a plastic hinge cover. I am wondering if I can remove the lower half of the case and unscrew the hinges to detach the lid without having to remove the motherboard to gain access to the display connector. Is there enough slack in the display cable to allow me to remove the display and disconnect the cable on the display side? This would be a much simpler repair than doing the teardown required to get at the other end of the display cable.
  • pete dracman Jan 19, 2013
    I'm also wondering if anyone has found a source for this screen.
2 Suggested Answers
SOURCE: How do I remove the LCD screen from a Samsung Blast?
you must take the back cover of and remove the six screws to access the lower portion of the phone. Once you've done this remove the qwerty keypad. When you slide the phone back down you should see the back of the slider and two additional screws. Good luck.
Posted on Apr 04, 2009
Bought a chromebook acer 14 but it will not turn on after fully charged
hi Diane.
How To Fix Your Chromebook If It Won't Turn On More users are reporting that their Chromebooks are not turning on or the screen stays black. For some the problem comes and goes but for others their machine just stays off all the time. If your Chromebook doesn't turn on there is a few different problems that can be the cause.
This article will go through all the possible causes. I've arranged them in order from simplest to fix to most complex so that you can go through them one by one until your Chromebook turns on again.
So just try each fix and stop when your Chromebook turns on! Cheers!
Fix #1: Connect Your Chromebook To Power Let's start with a very simple solution that worked for one of my customers at my computer shop. Simply take your Chromebook, plug it into the wall power outlet, and try to turn it on.
If that doesn't work no worries move onto Fix #2.
Fix #2: Power-Cycle Your Chromebook
  1. Unplug your Chromebook from power.
  2. Remove the battery is that is possible on your model of Chromebook (it isn't on most Chromebooks)
  3. Press and Hold the power button for one whole minute.
Now try to turn on your Chromebook.
Fix #3: EC Reset Your Chromebook Fix #4: Let Your Chromebook Charge For A Few Hours If the Chromebook is very low on charge it may just need to charge. Let it sit plugged in and charging for around four hours. I suggest leaving it plugged in over night.
Try turning it on in the morning.
Fix #5: Disconnect Battery And Power-Cycle (Advanced) Most Chromebook machines have a built in battery that is sealed inside. However most of the batteries are not that difficult to reach if you have a screwdriver and are careful.
Look up a disassembly video for your chromebook model on youtube and watch it to see where the battery is located.
  1. Unplug your chromebook.
  2. Open your chromebook to get to the battery.
  3. Disconnect the battery cable.
  4. Carefully move the chromebook so that you can reach the power button. Press and Hold the power button for one minute.
  5. Re-connect the battery cable. Make sure the connection is secure.
  6. Close up your chromebook. Plug it in.
Try turning it on now.
or try this link out might help you some more.
chromebook acer 14 but it will not turn on Google Search
Dec 03, 2017 | Acer Computers & Internet
Samsung chromebook pink screen
Probably a bad connection on the cables or a faulty screen. What is it like on an external monitor?
Sep 21, 2015 | Samsung Chromebook Series 3 XE303C12
My Samsung chromebook does not turn on! how do it get it fixed?
Hi
Maybe it is just the screen brightness that has been turned down to minimum? Can you increase the light on the screen via your keyboard?
Hope this helps :-)
Feb 19, 2015 | Samsung Chromebook Series 3 XE303C12
Cracked screen repair
Yes... all power sources should be disconnected / removed before fiddling around with internal components of a Computer / laptop / mobile etc. and please make sure your hands are free of static!
Sep 16, 2014 | Samsung Chromebook Series 3 XE303C12
Won't turn on unless plugged in
Either the battery is faulty or a wire is no longer connected properly. I would get the repairers to check their work.
Apr 28, 2014 | Samsung Chromebook Series 3 XE303C12
Samung chromebook xe303c12 turns on to white screen chrome screen then turns black with power light on
Here is a trick you can use: You can put the Chromebook into Developer Mode, then once it is in Developer Mode you can switch it back into normal mode and it should totally wipe the Chromebook without requiring any USB flash drive or any SD flash card etc.
But remember that just like a Powerwash or a USB ChromeOS restore, this process will wipe all local files you have stored on your Chromebook's SSD.
best of luck ! And be certain to return to let us know if this helped.
-JW
PS: Remember that when using a Chromebook you should never store important files locally on the SSD HardDiskDrive shelf; Instead, store them in your Google Drive or if you must store them locally use something like flash storage media. A Powerwash or a switching into Developer Mode will wipe all SSD local files.
https://support.google.com/chrome/a/answer/1360642?hl=en for Samsung Chromebook XE303C12-A01
  1. Press ESC + Samsung Chromebook Refresh key + POWER. The screen displays a yellow exclamation point (!).
  2. Press CTRL + D to begin dev mode, then ENTER. The screen displays a red exclamation point.
  3. Press CTRL + D, then ENTER. The Chromebook deletes its local data, returning to its initial state. The deletion takes approximately 15 minutes.
  4. When the transaction completes, press the spacebar, then press ENTER to return to verified mode.
Jan 21, 2014 | Samsung Chromebook Series 3 XE303C12
Samsung chromebook series 3 opens to a blank white screen and never connects to anything!
It appears it's time for you to warranty the book. Contact Samsung's warranty department with the information provided in your user manual.
Sorry to hear about the trouble.
Aug 25, 2013 | Samsung XE303C12-A01US Chromebook -...
Now my keys are sticky is there anything i can do?
Cannot repair but needs to be replaced. Chrck out this WEB site for a replacement.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Nov 08, 2012 | Samsung Chromebook Series 5 Arctic White...
Samsung Chromebook Series 5 3g Arctic White Atom N570 Ssd Wifi 12.1" Notebook Logo
291 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
