Question about Summagraphics Refurbished SUMMASKETCH MMII 1201 WITH 4 BUTTON PUCK WITH CABLE
Cursor jumps like mad on Summasketch 1201
A few years ago it started developing this problem - regardless of pen or 4-button puck, or tablet/mouse mode, the cursor jumps, usually in a trangular pattern, but it varies, most often it jumps one inch to the left and right, over and over, constantly. This makes use impossible of course. The jumping/jitter is extremely fast - 5 or 10/second.
I /thought/ it might be the power supply (cheap piece of chinese garbage which came in the original package) so I bought a nice regulated AC adapter - no change. I am thinking perhaps one of the chips in the tablet itself has gone bad. I opened it up and there is one big chip and bunch of small ones ("defining" the grid sensors I would think) . Do you think it'd be worth changing the large chip (IF I can find an equivalent) or is it trash time? Any other suggestions?
Thank you very much for your time.
Trash the piece-o-****
Posted on Jun 17, 2011
  • aelfric Jun 18, 2011
    I appreciate your polite, helpful and original reply. The problem was solved by using a real 12VDC power supply from an electronics store instead of little AC-DC adapters.
My pen for my bamboo tablet is placing the cursor one place on the tablet and and another place on he pc,what can i do to fix this?
Go to Control Panel and access the settings for the tablet: you can choose one of 2 mapping settings for the cursor:
1. Pen Mode: this is only to be chosen if the aspect ratio of the tablet matches your monitor aspect ratio (4:3 or 16:9 or 16:10) and only if the size of the tablet is comfortable enough
2. Mouse mode: the pen behaves exactly like a mouse
Please check these settings and choose the one that suites best.
Feel free to contact if you have additional questions
Regards,
Katharsys
Mar 30, 2011 | Wacom Intuos3 Graphic Tablet
My Wacom Tablet won't recognize the pen.
you have to install the pen on the CD you have from the box you got it in
Apr 21, 2010 | Wacom Intuos3 Graphic Tablet
How do you put the pen in "Mouse mode" on a Genius?
Please follow those steps:
  • Select "Preferences" under the "Options" menu .
  • Under the Digitizer Input section select for input "Digitizer only" and click OK
  • Now configure the menu and screen area and save configuration
  • Select "Preferences" under the "Options" menu and set in the digitizer input section input back to "Digitizer/Mouse"
Jul 24, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
I have a secondhand Summasketch Pro mm 1812. I
I just bought one on ebay - not sure what I'm getting myself into here! Doesn't seem to be a well-known brand... anyway, I found a manual here: http://www.gtcocalcomp.com/files/ss3.pdf and possibly some drivers, not sure really (!) here: http://www.gtcocalcomp.com/supportsummasoftware.htm
hope that helps!
Jul 09, 2009 | Summagraphics 12"x18" Summasketch Tablet...
The mouse on my Wacom Intuos tablet is not working.
I know this question was asked a long time ago, but I just had this similar problem and found a solution to it.
1. Install the latest Wacom drivers for your device
2. Open the Wacom Tablet Properties from the Start menu.
3. Click on the Mouse tool
4. Click on the Mapping tab halfway down the screen
5. Change the mode from Mouse to Pen
Dec 26, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Digital pen + SummaSketch III
Not sure what your problem is, the pen looks like the correct pen for a Summasketch III.
If you need to order parts or replacment digitizer got to this page where you can order them:
http://www.interwld.com/PriceLists/SUMUSPricelist.htm
More infor on the Summasketch can be found at this link:http://www.interwld.com/summa/summasketchIII.htm
And FAQ at this link:http://www.interwld.com/Home/FAQ.htm#SummaGraphics%20Digitizers
Gerry
Aug 30, 2008 | GTCO (01-0339-001) Digital Pen
Skipping and Shaking cursor
I had a similar problem years ago w/ my ss III 12x12 that had worked flawlessly for years. I talked to tech support and they said move it away from monitor (crt) or other source of RF interference - this did not help mine. I tried replacing the power supply w/ generic one - no help. I noticed that the power supply voltage was spiking when check w/o load. After talking to an electric guy I know, he suggested a voltage regulator. Finally I built a home-made voltage regulator and wired it into the generic supply line -Problem solved This was about 10 years ago - still working good today.
Feb 23, 2008 | Summagraphics SummaSketch III Graphic...
Initial Delay of tablet pen
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
Feb 02, 2008 | Wacom Intuos3 Graphic Tablet
Computers & Internet Logo
347 people viewed this question
Top Summagraphics Computers & Internet Experts
David Payne
David Payne
Are you a Summagraphics Computer and Internet Expert? Answer questions, earn points and help others
