SOURCE: Bizhub 420 Photocopier
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: what is the problem code c-2801 in my konica
SOURCE: minolta bizhub 420 code c2403
this error code means there is a problem with the toner bottle drive most likely the toner rotation sensor will need to be replaced
SOURCE: c5201 error konica minolta bizhub 420 i removed
reconnect again your fusing unit. then before you ON your machine you long press utility/counter then press the small circle black, then press trouble reset.off/on
SOURCE: bizhub 420 error code c-2801
error code 2801 plesce relese the code prectical met
