My kelvinator tumbledryer is tripping the main plugs
  • Washing Mach... Master
  • 17,129 Answers
Possible that there is excess power load due to some electrical shorts within the board, You need to check for the input front section of the power supply of the controller unit. There can be short in the surge capacitor, the rectifier or a short in the circuit.
Posted on Jan 17, 2013
How do I stop food freezing in the main part of my Kelvinator Twin air no frost 500 series refrigerator
there is a dial inside the refrigerator side to turn the temp up or down . rotate the dial to a lower number for warmer
Aug 31, 2016 | Kelvinator Refrigerators
Where is the fuse for a 9 year old Kelvinator undercounter oven situated?
There is none. Look in the circuit breaker box on the outside of the house for the one marked oven. It will be 2 breakers side by side with a metal part connecting both levers together. Move both handles back and forth a couple of times. That may restore power to the heating element. If one breaker trips it leaves 120 volts to work the light and the clock, but the element is 240 volts. It may have shorted with age. You may need to replace the elements if the breakers keep tripping after you reset it at the panel.
Jul 28, 2016 | Ovens
I have a kelvinator Electrolux split air con model r51k/bge it doesn't seem to keep coolits set on 17 and the control says cool the fan says high but no cold air comes out wat could be the pro
many reasons could be there, check that the outdoor fan working or not if yes my be the compressors is tripping, if no, check the volt for outdoor, check the gas and the leakage
Nov 21, 2014 | Electrolux Heating & Cooling
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Feb 17, 2010 | Zanussi Dryers
F&P ECS Gentle Annie, Frigidaire & Kelvinator model compatibility
Almost all parts are interchangeable- Gentle Annie and Frigidaire are all the same machines- only parts different are main power board in base of machine, and display board- everything else the same. Motors are interchangeable, as long as the plug connection is the same- there are two different types of plug connection (ie male and female plugs are opposite ways around).
Aug 26, 2009 | Frigidaire Washing Machines
Hotpoint condenser tumbledryer
Check the amp use of your dryer and compare it to the fuses.
If the dryer is taking more amps than your fuse can dish then it will blow. Upgrade your fuse and/or breaker to a higher amp rating.
Nov 06, 2007 | Dryers
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
