Operating instructions for setting up zeatek decoder
I have followed all the instructions for the OVHD decoder, but keep getting the message No satellite signal despite having no problem with my DSTV Decoder using the same satellite dish
check the alignment and cables also check make sure view unobstructed --if good open menu and check settings go through list if still problem call provider and ask for tech services
Aug 14, 2016 | Televison & Video
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
How to set the compatible DVD decoder of samsung external DVD drive.
hi. my name is rui i will answer your question regarding your problem about how to setup a compatible dvd decoder for sumsung external dvd drive.
1st of what's the model of yoursumsung external dvd drive?
2nd if you have a internet connection and know the model of your dvd drive you can download a compatible decoder for your sumsung(model)using google.
here is one that you can try out its a NVIDIA PureVideo Decoder (NVIDIA DVD Decoder) 1.02.186 (Samsung Dvd Decoder).
NVIDIA PureVideo Decoder is a combination of a hardware video processor and video decode software for playback of DVD and MPEG-2 videos using Microsoft Windows Media Player and Windows Media Center Edition.
you can download it @ http://samsung-dvd-decoder.fyxm.net/
it's easy to use just follow the instruction...
hope it helps you in anyway.^_^
Jul 17, 2011 | Samsung Computers & Internet
The windows cannot read video in media player. So, the screen appear the problem that the media player does not install a Compatible DVD Decoder. So, How I Install The DVD decoders?
if you are looking for a decoder then download the file in this website
http://www.updatexp.com/dvd-decoder-media-player-windows.html
i hope this is helpfull
akuma_ryu21
Jan 21, 2011 | Microsoft Windows XP Professional
I need to decode my ford stereo the serial number is m138243 many thanks
Your code is 3034
Ford  Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate
Oct 10, 2009 | 1998 Ford Escort
Cd drive showing instead cd-rw/dvd drive
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 02, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My samsung dvd rw combo is not reading any DVD. it is only reading cd.
To work around this issue, open Control Panel, and then follow these steps to configure the DMA/PIO settings for a controller: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand IDE ATA/ATAPI Controllers. 3. Right-click the controller that you want to configure DMA/PIO settings for, and then click Properties. 4. Click the Advanced Settings tab. 5. In the Transfer Mode box, click either PIO Only or DMA if available
Troubleshoot DVD problems loadTOCNode(2, 'moreinformation');
Jul 19, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Decode
i lost my password
my code is: 21344 13898 6789 8507
May 20, 2008 | BenQ MP610 Multimedia Projector
I have a panasonic SC-PT850 DVD home cinema system, and although it says it is DTS and Dolby 5.1 compatable but it does not give out any sound at all when i play Blueray films or Playstation 3 games which...
Not so much an answer more a shared problem with a slight insight. On the Panasonic manual page 40 http://www.panasonic.ae/EN/Manuals/SC-PT550%20-%20850W.pdf
It states the following: This unit can decode the surround signals received through cable TV box, digital broadcasting or satellite broadcasts. Refer to your equipment’s operating instructions for details. Only Dolby Digital and PCM can be played with this connection.
So it sounds like the SA-PT850 unit will decode DTS from an internal source ie DVD but not from an external source ie ps3 or WDTV which is a shame because I own a WDTV. The solution for me is to convert the dts to ac3 (Dolby digital) which works great. But not sure if this is an option for you.
May 08, 2008 | Panasonic Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
