When I go to save a mixed down program to a blank CD-R and follow the usual steps to do so, (select save program, then select IDE, then select CD-DA) it takes me to a screen that says from top to bot
Sudden problems saving music to a CD-R
  • 84 Answers
Pull the cd drive look at the back smell it make sure its not burning up easy to check on the back of laptop there is a pic of a disk unscrew that screw gently tug or pry it out with laptop off not in hibernation mode pull it out look at the back of cd drive and look inside the cd bay with flash light look for darkness on connectors smell inside cd bay try that 1st making sure it is working correctly and power up laptop witout cd drive connected let it see it without it in then after boot shut down put cd drive back in and restart ok try that
Posted on Mar 04, 2013
  • 55 Answers
SOURCE: K17A Pioneer DVD-RW - Won't recognize blank CD
Then might have a problem,if is it still in warranty you should return it to your dealer(have you tried formatted the blank cd first?many programs such nero or alcohol gives that option)
Posted on Apr 15, 2008
  • 13433 Answers
SOURCE: Acer Aspire wont boot up
if it doesn't save the bios settinsg, then most likely the memory battery is empty or disconnected. replace the memory battery and try again.
Posted on Jun 07, 2009
Muzzi_123
  • 749 Answers
SOURCE: Media Test Failure, Hardware Problem?
reset your BIOS settings to default, to do this go into BIOS screen and choose return to default settings.
Posted on Jun 17, 2009
  • 236 Answers
SOURCE: I'm unable to save the pictures that I take in
"save as....." function
Posted on May 12, 2010
  • 24 Answers
SOURCE: boots only to bios settings, then blank screen
It would be due to a virus problem which has corrupted your os..Try inserting your os disk at boot and then restart and the press del or tab or f8 key at the bios setup page and then goto advanced bios options and change the primary boot device to disk drive and change the secondary boot device to hard disk and then save changes and reboot,now your laptop boots from the disk and you can reinstall your os..Hope this helps you..All the best..
Posted on Dec 11, 2010
I dont know how to burn a movie to a blank dvd
open up your burning program depending on which burning program you have you can select either dvd or cd to burn an iso or make a cd/dvd movie once you have made your choice a browser should open navigate to your video file/s select it you might have to select an iso
((will depend on which burning program you have)) add to you should a graph oh how many mbs have been used once it loads select burn
if you dont have any burning software to burn dvd's
there are plenty of free burning software programs on the internet
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
hope this helps you
Aug 29, 2011 | HP DVD1040e DVD-RAM Burner
Not detecting windows xp booting cd vista booting dvd detected but showing size 0 canot creat patition what io
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jun 29, 2011 | Fujitsu (MHT2040BH-50PK) (mht2040bh50pk)...
I forgot my password and now i cant get in my computer what should i do
1. turn off computer
2. unplug power cable
3. hold down power button for 3 seconds
4. remove side panel
5. locate jumper in JP1 and remove it
6. plug in power cable
7. power on computer and enter bios - should be clear
8. save and exit
9. repeat steps 1-3
10. reconnect jp1
11. put side panel back on
12. repeat steps 6-7 to verify bios password is gone
Sep 06, 2010 | Dell Dimension 2400 PC Desktop
My Friend just received a cleaned T21 from her workplace. When I try to boot it up I get the following: Initializing MBA. Pres Ctrl+Alt+B to Configure... Managed PC Boot Agent (MBA) V 4.12 UNDI Initialize...
try clicking on this link and choosing Master Boot Record Repair.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-56102
Also, have you tried
Step 1. Make the DVD drive the first startup device in the startup sequence using
the following procedures:
a. Shut down the operating system and turn off your computer.
b. Press and hold the F1 key, and then turn on the computer. When the logo
screen is displayed or if you hear repeating beeps, release the F1 key. The
Setup Utility program opens.
Note:
If the Setup Utility program does not open, shut down the
computer, wait approximately five seconds, turn on the computer, and
then immediately press and release the F1 key repeatedly until the Setup
c. Use the left and right arrow keys to select Startup from the main menu.
From the Startup menu, select Startup Sequence and then press Enter.
d. From the Startup Sequence [Primary] menu, do one of the following to
select the DVD device that you want to use as the first boot device.
Note: When selecting your DVD device as the first boot device, be aware
that internal DVD drives are listed as IDE CD. If you will be using a
supported external DVD drive as the first boot device, select USB
CDROM in the steps below for your choice of DVD device.
v If your choice of DVD device is already listed as the first boot device,
continue with step 2.
v If your choice of DVD device is listed in the startup sequence as any
device other than the first device, select it and press the Plus (+) key
repeatedly until it is displayed as the first boot device. Continue with
step 2.
v If your choice of DVD device is listed as an excluded device, select it
and press the X key one time to add it to the startup sequence. Then,
select your choice of DVD device from the startup sequence and press
the Plus (+) key repeatedly until it is displayed as the first boot device.
Continue with step 2.
e. Press F10 to save and exit the Setup Utility. When the save and exit
message displays, select Yes and then press Enter.
Jul 18, 2010 | Lenovo ThinkPad T21 2647 Notebook
How do i get movie files on my pc and burn it to a blank disc
insert a blank CD on your PC, then right click on the movie file and click on send to- CD/DVD drive
then follow the screen by clicking on next until you get finish.
Sep 03, 2009 | Samsung Super-WriteMaster SH-S162A DVD?RW...
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
CD drive is not recognized
Step 1: Checking for CD/DVD drive in BIOS
Make sure the drive appears in Setup. The drive has to be detected in the Basic Input/Output System (BIOS) before Windows can see the drive. Check for detection as follows:
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
May 27, 2008 | Computers & Internet
My dvd-rw can't read dvd but can read cd
•HKEY_LOCAL_MACHINE
•SYSTEM
•Control
•Class
May 18, 2008 | Computers & Internet
Word perfect 10 freezes after 20-30 mins of use and won't print or save
Un-install program, restart PC than re-install program. That usually works for software issues.
Possible file corruption. Wouldn't hurt to run a virus scan of the entire system. ( is your virus scanner up to date?)
Good Luck & Kind Regards.
Mar 19, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
