Question about The Times Max ER-1500 Electronic Time Recorder, Fully automatic, Up to 4 columns, Automatic positioning (ER150... (ER1500) UPS System
Max electronic time recorder ER-1500 shows error code E-69 01, What does this means?
2 Suggested Answers
SOURCE: how to adjust the time for Max ER-1500
HOW CAN I?
Posted on Aug 01, 2010
MAX ER 1100
Hi ,our company is Wuxing baisi office consumable co.,ltd . we can offer Max ribbons . like Max ER-1100 ER-1500 ; Max ER-2200 ER-2500 ER-3100 ER2200 ER2500 ER3100 /Max ER-IR102E. Please contact me at info5@baisi-office.com
We can do B2C, B2B business.
Mar 06, 2014 | The Times Max ER-1500 Electronic Time...
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
I have a Max ER2100 Electronic Time Recorder where can I find an instructional manual?
Hi kevin Here's the manual for the er-2100 Electronic Time Recorder.
Iam sorry for the quality on the pictures but i dont have a scanner,,,,anyway i hope this helps you.
http://imageshack.us/g/716/img1500vi.jpg/
Sep 30, 2011 | The Times Max ER-1500 Electronic Time...
How do i change the time
In order to change the time you need a key card. Do you have a key card and authorisation?
Mar 02, 2011 | The Times Max ER-1500 Electronic Time...
E-EE
Let us know the exact problem. From when are you facing the problem.
Feb 23, 2011 | The Times Max ER-1500 Electronic Time...
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Computers & Internet Logo
79 people viewed this question
Top The Times Computers & Internet Experts
David Payne
David Payne
Are you a The Times Computer and Internet Expert? Answer questions, earn points and help others
