Question about Canon imageRUNNER C2058 Led Printer
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
  • 22 Answers
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Posted on Mar 15, 2009
What do I do when my printer gives me a error code of e748-2024?
recommended main board 1reseat everything on the boards and the connection between the two there is a comms problem between Cont 1 & Cont 2
Sep 01, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon color imagerunner C2050 has a code Eo70-0001 what should I do
Check the home position sensor on the transfer belt. Make sure its not dirty. Also I think there may be some aluminum tape on the edge of the belt for the home position sensor to see, make sure its still there and did get ripped off. I did't actually work on this machine but these are the usual problems on other models.
Oct 09, 2012 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon color image runner c2050 is giving me a code E070-0001 and need to know what to do about it.
The error means that there is a problem with the transfer belt unit. You may need to replaces the transfer belt unit. You may need a service person to resolve your issue.
I am not able to replace black toner in Canon IR C2058 as cartridge in not going in fully. What can I do
lower the developer unit handle and take out the blk DV and then take out the toner cart:and use a flash light i see what blocking it from coming out.
Nov 17, 2009 | Canon imageRUNNER C2058 Led Printer
Canon imageRUNNER C2058 Color Copier/Printer service manual have error e240-0000
E240 Error in communication of controller
0000 Error in communication data Check connector, check connection of sub PCB in the
controller box, check / replace DC controller PCB /
main controller PCB
0001 There is no response when 3 sec passed since the main controller had sent the pickup
request to DC controller during printing.
0002 There is no response when 4 sec passed since the main controller had sent the request
for image output to DC controller during printing.
0003 The engine is activated when jam occurs.
Jul 09, 2009 | Canon C2058 Color Copier
Canon ImageRunner C2058: Repeated noise in image. Drum issue?
The upper fuser roller is probably worn out. If the spot is of a particular color, then it may relate to that drum unit.
Jun 21, 2009 | Canon Office Equipment & Supplies
Admin password for Canon ir2270 MFC
JUST HAD THE SAME PROBLEM. THE DEFAULT ADMINISTRATOR PASSWORD IS "BLANK" LEAVE THE PASSWORD FIELD EMPTY AND PRESS ENTER
Mar 17, 2009 | Canon Office Equipment & Supplies
CANON IR C3200
Hi there, your printer is experiencing a shortage due to a lose connection that's located on the backside of the control panel. you will have to disassemble and remove this control panel to find this lose connection. this connection seems to be linked to the power board which explains why the screen turns black.
Feb 18, 2009 | Canon imageRUNNER C3200 Color Printer
Print function says wait.....
pretty common need to replace print board try nationwide board repair
Oct 28, 2008 | Canon C2058 Color Copier
207 people viewed this question
old marine
old marine
