Question about Faema FA60081
Where can i get the machine error for faema barcode?
Where do I find a Faema Smart A2 replacement touch pad? The left push panel is not working and the guy fixing it wants me to order a new one but I can't find a matching part anywhere on the internet.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Feb 09, 2015 | Faema Smart A2 Automatic Espresso Machine...
Faema E92 error codes E51 and 58 What to check?
Google this question and then post your answer as a comment to update others as well.
Nov 23, 2014 | Faema Coffee Makers & Espresso Machines
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
Jun 06, 2014 | Faema Smart A2 Automatic Espresso Machine...
I have a Faema X2 Grand Italia C/10 NF and looking for descriptions of error codes (specifically #055). Is there a manual that gives such information?
ERROR 055 IS KTY PLUGS TO THE GROUP IN MY MANUAL,I'M A TECH AND THIS IS WHAT THE DESCRIPTION SAYS IN THE X2 TECH MANUAL... under possible causes it says either KTY disconnected or Malfunctioning card..solution is to open the machine CHECK CABLING/REPLACE KTY/REPLACE THE CARD.. hope this helps!!
May 09, 2012 | Faema Coffee Makers & Espresso Machines
Need a users manual in english for the faema due espresso machine
Try Googling (faema)(FA60081)(manual) without parens. You may have to refine your search to get an English version.
Oct 10, 2011 | Faema FA60081
I have a Faema special. model no.537212 I need the schematics
I have no clue about this product, but at the terminal board how many
wires come from machine to the board,or just wires coming from machine. A 220v, should have 2 hot, neutral,gr, so 4 wires. Depending
on what it looks like, the wires come from machine to a board or just wires.then the colors of those wires.
You should send them an email asking for help or schematic.
I posted there website below. Sorry could not help further.
http://www.faema.net/site/index.html
Apr 07, 2009 | Faema FA60081
I would like to know a place where i could get the technical and part manuel of the following machine: ''FAEMA E91 A Diplomat'' And please if you can get it in french version it would be appriate thanks...
FAEMA COMPANY LTD. M6G 1Z6 Ontario and Western Canada ADDRESS _t.gif 672 Dupont Street, Suite 201, Toronto TELEPHONE _t.gif 001 416 535 1555 FAX _t.gif 001 416 535 3843 EMAIL _t.gif espresso@faema.net _t.gif iko_piu.gif _t.gif FAEMA DISTRIBUTEUR, INC. QC H2R 2W5 Montreal, Quebec ADDRESS _t.gif 14 Jean-Talon West TELEPHONE _t.gif 001 514 276 2671 FAX _t.gif 001 514 276 5991 EMAIL _t.gif sales@faemacanada.com
Mar 16, 2009 | Faema FA60081
Faema S-87 Spouts copious amounts of water from the top
There could be one of 2 things happening :
1. Problem with auto level.
2. Most likely the inlet valve has a small leak.
Jan 26, 2009 | Faema FA60081
Coffee Makers & Espresso Machines Logo
215 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
