Question about RCA F32650 32" TV
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
  • 4 Answers
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Posted on Jan 27, 2009
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
My rca tube tv has a high pitch whine when i plug it in no picture also
Hello you have a shorted Horizontal output transistor, also if you replace it also have the Flyback transfromer replaced also, these parts work in conjunction with each other, and if one goes bad its best to replace them both.
Dec 20, 2009 | RCA F32650 32" TV
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RECOR COLOR TV dead high pitch whining noise
you have a short in the horizontal ckt,look for diodes,horizontal output it might be damage or a bad cap, if not the fly-back transformer is gone.
good luck
Oct 20, 2008 | RCA F32650 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection basicaly a large coil of copper can take silcon and put on the effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F32650 32" TV Logo
145 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
