Question about Toshiba PORTEGE Z830-104
Toshiba portege z830 motherboard replacement - Toshiba PORTEGE Z830-104
My Laptop is Toshiba Portege. I want to use te calculator but can not find the number Lock on my keyboard. Where is it?
On my Toshiba Portege I access the overlay number pad by pressing Fn- F11. Try it. To get of that mode, press the Fn-F11 combination again. The led on the F11 key should turn off.
Aug 17, 2011 | Toshiba Portege 3500 Tablet PC
My Toshiba Portege M200 just stopped charging and wont even turn on? Is this the battery? Or what? The charger will be plugged in the wall and plugged in the laptop but nothing?
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
Mar 22, 2011 | Toshiba Portege M200 Tablet PC
What is the replacement screen part number for the Toshiba Portege 3505?
i believe this is your part number is P000363830
you can always confirm by looking at the screen itself. the part number is usually on the back of the screen on a small piece of sticker
Dec 05, 2010 | Toshiba Portege 3505 Tablet PC
Audio driver toshiba portege 3500
Go to the Toshiba website and download the updated drivers for your system. They are free.
Oct 14, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba Portege Video problem
I found the same problem on one that I bought from a guy for $100. He had been picking it up by the screen and every connector in the screen and the pivot came loose. I was able to tighten every thing back up and now I have a real nice laptop.
Aug 12, 2008 | Toshiba Portege M205-S810 Tablet PC
Toshiba Portege 500 Laptop
need a toshiba mother board for m40x250
Aug 04, 2008 | Toshiba Portege M400-S5032X Tablet PC
Clock of the computer
This means that the cmos battery on the motherboard is flat and keeps losing time and date and probably the memory settings, this is only a small disc shaped watch type battery CR2032 and can be found on the motherboard, a pc repair shop would be able to do it for you for a small fee.
Jun 14, 2007 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba PORTEGE Z830-104 Logo
127 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
