SOURCE: it doesnt print
delete your printer from your computer and reinstall it.
This will reset it. Make sure you have your cd with software and drivers handy or that you can download drivers from your printer company site under support of you device first.
You shouldn't need the drivers but just incase.
After you delete your printer out reboot your computer and reistall your printer. If running windows 2000,xp or Vista it should reistall it when you reboot.
SOURCE: GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
