Question about Sharp FO-2081 Copier
Sharp FO-2081 clear memory error - Sharp FO-2081 Copier
  • 71 Answers
I service Sharps for a living.
Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Posted on Dec 30, 2014
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
SOURCE: SHARP FO-5600 - THE MACHINE
CDURHAM,
I found the answer to this on page 22 of the PDF manual that can be downloaded from http://www.sharpusa.com/files/fax_man_5700.pdf.
Posted on Sep 04, 2008
  • 48 Answers
SOURCE: sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
Posted on May 25, 2009
  • 48 Answers
SOURCE: Life button on Sharp FO 5550
Look at your rapid speed dial keys from a to z you need to flip over your page plate.
Posted on May 27, 2009
FixinFax
  • 3085 Answers
SOURCE: sharp FO-3150 polygon error
You have a bad laser unit that can't be replaced.
Posted on Jan 16, 2010
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
Apr 08, 2014 | Sharp FO-2081 Copier
Memory full on a sharp FO-2081
Enter simulation mode using # * c * and then run test command
66-10 to clear image memory. This happends if you get a garbled fax from interference or noise. You should get a power filter with fax and network ports if it keeps happening.
Apr 03, 2014 | Sharp FO-2081 Copier
Fo-2081
I am a tech that Services Sharp. Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Dec 13, 2013 | Sharp FO-2081 Copier
Clear memory
Dec 05, 2013 | Sharp FO-2081 Copier
Clear memory full
I am a tech the services these machines. Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Nov 07, 2013 | Sharp FO-2081 Copier
Clear memory full
I service sharp for a living.
Oct 07, 2013 | Sharp FO-2081 Copier
Clear memory full
I work on these machines.
Sep 03, 2013 | Sharp FO-2081 Copier
Clear memory full
I service Sharp for a living.
Aug 08, 2013 | Sharp FO-2081 Copier
Sharp FO-2081 Copier Logo
187 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
