Question about Uniden Cordless Phone
Need phone to store area code - tc27831fe2-b
My province now requires me to dial 10 digits instead of 7. The phone only stores 7 digits in the caller ID. How do I make it store all 10 digits so I can call someone back from the caller ID?
  • Uniden Master
  • 2,460 Answers
Delete the area code. It's in the instructions.
Posted on Jan 25, 2009
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
How to closed zero dial in this phone set
phone circuits included electromechanical relays which imposed limitation on the speed of dialing a digit, and therefore dialing a complete 10-digit telephone number could take up to ten seconds, during which hardware resources had to be dedicated to a circuit. The Bell System organized the numbering plan to minimize the cost of providing automatic dialing to large population centers. The second digit of all area codes was 0 or 1, while the second digit of the exchange triplet was never 0 or 1, thus facilitating the recognition of whether a user was dialing a full 10-digit number or merely dialing within the local area code. In this coding scheme it was not yet necessary to dial a leading 1 for access to long distance circuits to other area codes. In some regions, local numbers were 7 digits, or occasionally less, but a toll call within the area code required a preceding 1. Area code 617 in eastern Massachusetts used this system in the early 1970s, while the Chicago area (312) did not. In the Chicago area, one could call the Boston area by dialing only 10 digits, while in Boston, to call Chicago, one would be required to use 11 digits, including the prefix 1.
Dec 19, 2013 | NEC Lands Phones
When my messages come through on the phone it only shows the number and not the name of the person who sent it. How can I solve this problem?
Sometimes, caller ID (the name of the caller) does not appear on a call and is replaced with the phone number.
The main reasons for caller ID not working are:
1. Duplicate entries in contacts - by FAR the most common cause and unfortunately, the most awkward one to fix.
If the phone finds the same number against more than one name, it doesn't know which to use so, perfectly sensibly, it defaults to showing the number.
The only way to fix this is to remove duplicates from your contacts. Best way to do this would probably be in Outlook on the PC, but assuming you can't do that, then you have to find the numbers that aren't working a use the LATEST version of the Nokia Search Tool (http://europe.nokia.com/ovi-services-and-apps/search-o1) to find the duplicate entries:
NOTE: when you search, use PART of the number to avoid problems with formatting: searching for +441234567890 will NOT find +44 123 456 7890 whereas searching for 789 would.
2. Using your international dial code instead of '+'
Not sure if this applies to all phones, but if you store your number using your county's international dial code (eg: 004412345678990 - WRONG) instead of the '+' sign (+4412345678990 - RIGHT), it can cause problems.
3. "(0)" area code prefixes
Only a problem if you synch with MS Outlook. When you specify a country in MS Outlook, it will insert "(0)" into your phone number after the country code - while somewhere in Redmond, Bill Gates cackles - so +4412345678990 becomes +44 (0) 12345678990.
You need to remove the (0).
4. 9 and 10 digit numbers
There has been one report of problems with 9 and 10 digit numbers where one size doesn't work with SMS and the other with calls. Not sure that anyone else has ever come across this.
Feb 13, 2010 | Nokia 5530 XpressMusic Smartphone
When a received call comes in the number shows 1-402 then the number.on call back the phone dials all 11 numbers,then i get a recording from windstream that says i dont need to dial the 1 and area code....
The caller ID in your area is set up to show the 1 plus the area code although not every area has yet to require you to dial the 1 before the number. In the near future it's possible you will have to dial the 1 even if you're calling a local number. I know of no way to change the phone settings in order to remove the 1 in the caller id. Unfortunately it looks like your only option will be to dial the number directly without the 1. Good luck!
Dec 10, 2009 | Panasonic Lands Phones
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
Apr 21, 2009 | GE 29267 Corded Phone
Does the Dect 6.0 recognize when a phone number needs a 1 before the area code (1-800-.......)?   I entered some numbers with the required 1, and some without it.  All the calls went through.   In a few...
If you save from caller ID to the phone book from an out of area code number, the manual doesn't tell you that you have press the * key while the number is displayed and it will insert a 1 before the area code. Do this before trying to call from caller ID or copying the number to the phone book. I had to delete the area code stored in the global set up to get the caller the "*" feature to work for my local calls other wise it would just put a 1 in before the 7 digit number and would not work when it is store.
Jan 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Dec 05, 2008 | Panasonic KX-T7431 Corded Phone
I have caller ID with phone company and we recently, in our area went to 10 digit local dialing in our area.My Uniden cordless phone tru9488 still only shows 7 digits on the call display. one other phone...
Somewhere, like on pdf page 48 there's a note about 7 digit dialing. In MENU GLOBAL SETUP AREA CODE it displays yours. Press DELETE and OK and it goes away.
Here's the manual: http://www.uniden.com/pdf/TRU9488om.pdf
Carl
Oct 23, 2008 | Lands Phones
Area code
Here is a link to the site containing a pdf manual link and this is an excerpt for you :
Long Distance calls and Area Code Setting/Cancellation
While the present Caller ID information is displayed, pressing */tone/< will place
or remove the prefix "1" in the display to set the call for a long distance call, or
pressing #/> will set or cancel an area code (see page 30).
Storing Caller ID messages in the Phonebook
Messages shown in the Caller ID list can be stored in the phonebook. The phone
number and name of the party on the Caller ID list can be stored in memory.
1) When the phone is in standby mode, select the Caller ID message to be stored.
Then press the STORE soft key on the base or the EDIT soft key on the handset.
From the handset, then select E D I T ?. S t o r e / E d i t N a m e appears. If the Caller ID
message is already stored in memory, you will hear a beep and T h i s d a t a i s
a l r e a d y s t o r e d ! ! appears. The number will not be stored.
2) To complete the setting, follow the steps 3-8 in "Phonebook (Storing Phone
Numbers, Names, Distinctive Rings, and Speed Dial)" on pages 42-43.
Dec 17, 2007 | Uniden TRU8885-2 Cordless Phone
Uniden Cordless Phone Logo
120 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
