Question about Matsonic MS8147C+ (N82E16813184008) Motherboard
Need manual for the ms8147c+
I need the front panel pin settings need to now where the 2 ground,2power,d2-,d2+,d3-d3+, and the reset,hdd,powersw,powerled goes.
  • redrose64 Jan 25, 2009
    I got it fixed ty
  • nditndot Feb 19, 2009
    yes i need the manual...too
  • 565 Answers
Google is your friend
Posted on Jan 25, 2009
Headlamps inoperative daytime running lamps come on then go out jumped out headlamp switch ground circuit out still no headlamps.
It sounds like your DRL RELAY/Headlight relay. I had this happen with a 2000.
Please rate me if this helps You.
Here is some info that I hope is helpful to you.
This first part is how to disable the DRL
TOYOTA. From the Toyota technical service bulletin EL011-00 Web site for specific models determine where the module is; either the DRL relay or the body ECU, connector number, pin #. Oct 6,2000.
Avalon 1999 DRL relay D4 pin 1
Avalon 2000 body ECU B5 pin 6
Camry S/D 99* DRL relay D6 pin 23
Camry S/D 00* DRL relay D6 pin 10 *twilight sentinel
Camry Solara99/00* DRL relay D6 pin 23
Celica 2000* body ECU B6 pin 17
Corolla 99/00* DRL relay D3 pin 23
ECHO 2000 DRL relay D2 pin 12
4Runner 2000 DRL relay D8 pin 2
Land Cruiser 99/00 DRL relay D8 pin 2
MR2 Spyder 2000 DRL relay D2 pin 12
RAV4 99/00 DRL relay D17 pin 2
Sierra 99/00 DRL relay D4 pin 2
Tacoma 2000 DRL relay D8 pin 2
Tundra 2000 DRL relay D7 pin 2
-disconnect battery- Then remove the wire with pin attached and tape to the harness. (consider just cut and tape the wire) -check operation- [except the 2000 MY-Avalon, additionally you need to ground the wire at the module end of the cut wire]
And here is the Headlamp relay part number.
1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif ACDELCO 1pixel.gif 1pixel.gif E1717C 1pixel.gif 1pixel.gif [RELAY-HEADLAMP] RELAY,HDLP OEM#89057700 ALL MAKES
Mar 19, 2010 | 1998 Toyota Corolla
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Codes
0= 98 BO BA 52 D3 21 08 B4
1= D2 EA 29 B7 B5 52 E9 AD
29TH NOV GOOD LUCK
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Telewest codes
t pst
0=98 B0 BA 52 D3 21 08 B4
1=D2 EA 29 B7 B5 52 E9 AD
New codes
telepest codes 29TH NOVEMBER 2008
00=98 B0 BA 52 D3 21 08 B4
01=D2 EA 29 B7 B5 52 E9 AD
Front usb connections
I finally found a solution, on a dead page in google cache only:
http://www.pcclub.com/forum/messageview.cfm?catid=27%26threadid=16567
The solution was posted by JontyBonkers.
The pins go like this:
1 2 3 4 5
_ 6 7 _ 8
1 = ground
2 = ground
3 = D1-
4 = ground
5 = D1+
6 = D2-
7 = D2+
8 = +5V
It seems that the case for those Packard-Bells had a small circuit board that divided the 5V line to both sockets.
D- are usually white, D+ - green, 5V - red, ground - black
Jun 11, 2008 | Packard Bell Computers & Internet
Pioneer D2
Found this online:
In order to watch the AV source in the AVIC-D2 or to have all the NAVI function while driving you must do the following:
1. Ground the original parking wire (Must Do)
2. There will be a open pin in the wiring harness under the ground wire. You must also ground this pin. I just pulled the wire out from the cellular mute pin and stuck it in the new pin and grounded it.
Nov 07, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Matsonic MS8147C+ (N82E16813184008) Motherboard Logo
363 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
