I am a technician i have to repair PANASONIC TV MO. NO.TC-21T200 i want to know where is its x-ray protection
Model no.21t200
  • 31 Answers
SOURCE: Panasonic Model TC - 32LX60 will not come on...red flashing light
hello it sounds like a main board issue but try this number and explain exactly ur issues to them they may say they only give info on parts but trust me just keep working ur way up and ull get some answers 800-833-9626 pannys parts and service their service manuals are horrible and not very much info that is really valuable is included in their service manuals another way to make money imagine that.
c
ill keep researching ur problem let me know if u get anywhere
Posted on Oct 26, 2008
  • 362 Answers
SOURCE: Does the Panasonic TV Model TC-26lx50 have a digital tuner?
Hi mrfeld, The TC-26x50 has only an analog tuner, if you want to recieve the new broadcast OTA signals you will need a Set Top Box. Let me know if you need further explanation and please rate this solution. LOne99star
Posted on Jan 16, 2009
localwonder
  • 6784 Answers
SOURCE: Where to get LCD screen for panasonic TC-32LE60 TV ?
Hi there, the only close part you could get is the actual cabinet. the actual screen will have to be shipped by the manufacture itself. these screens are filled with a liquid that is dangerous and has to be installed in a OSHA approved shop.
Posted on Feb 18, 2009
gopakumarg43
  • 74496 Answers
SOURCE: panasonic tv model no.TC-21RX30P
Hello
What is the problem with your Panasonic TV? you only mentioned its model number here. No problems reported. Please clarify the problem with details. OK.
Posted on Feb 14, 2011
campbellzc
  • 9 Answers
SOURCE: We have a Panasonic Viera
To connect, you would need to hook up either your wireless into an HDMI port or DSL/Cable line into the connector provided. Once you have this hooked up, go to the menu options, go to the picture of the wrench which is the settings options, and select the connection option you are using for the t.v.
Posted on Mar 18, 2011
??How to fix a PANASONIC PLASMA TC-P60UT50
Could be the SC, but also might be either the SU/ SD causing the SC to go into protect. Pretty easy to determine, if you look at the SU SD and see any holes or burn cracks that would be the problem. Let me know if this works or can help further.
Apr 13, 2016 | Panasonic Televison & Video
Tv. TC-P42X1X. in protecction.
Might be a problem with bulged capacitors - its one of the most common faults on any electrical item - best take it to an electrical repair shop.
Unusual on a Panasonic television as they are the best you can buy for a reason they used to use the best capacitors and internals.
Apr 11, 2014 | Panasonic TXN/A1EQUUS TNPH0800 Main Board...
Plasma screen suddenly went out
its a lcd ? replace the lcd lamps or the inverter
May 04, 2012 | Panasonic Televison & Video
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
WHILE WATCHING MY TV TONIGHT I HEARD A LOUD POP AND NOW NO PICTURE JUST BLINKING RED LIGHT
10 blinks for this tv is not always an A Board issue. It can be a problem with the power board as well. A technician should look at the set to dertermine where the problem lies otherwise it is just a guessing game of inni minni miny moe.
Apr 03, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Panasonic tv plasma blinking red led
This is what it says on Panasonic's website:
"Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases."
You'll probably need to call a repair man to fix your TV.
Mar 05, 2011 | Panasonic TC-50PX24 50 in. Plasma TV
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
No video
yea since the tv was replaced you can call the same technician and let him repair the tv the problem is in the video section or related circuit.good luck.
Apr 16, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
