Question about Shinco PMP-1700 Portable DVD Player with Screen
Sony A263 PMP Player Locked.
'm using a Sony A263 PMP Player. Now it's stucked and showing a LOCK symbol in the Screen. I Cn't open any files. How i can unblock it and open de files. Pls advice me.
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
My sumsung U5 mp3 player device showing in computer but the files is not showing and not opening
If the player is showing but not the files it will be good to use a search on the drive- the player as the search object- for all types of files.
If there is some lock on the files then it will not show up and will need to check if the folders are locked, but a search will indicate al files which can be opened.
Also in the first place check the properties of the player which will indicate the memory used in the player.
Feb 12, 2011 | Samsung YP-U5 MP3 Player
My China made PMP Player Hung Up
same problem i encounter when i place a MP3 file on the Music folder and add some NES games, but when i try to look the NES games on the application on my Sony PMP-Player it stock me on this windows without responding, but when i try to reset, it give me a problem on loading like the little globe pictures and no continue loading anymore.. please advice us what would to do on this problem..
Sep 05, 2009 | Sony Cameras
I d0wnload music and pitures and they show on my cumputer but not my device the device is like a ipod but much more it takes pitures and so on.......... by sony its portable pmp player
Have you transferred the files from your computer to the player? Are they in a format that the player recognize? You shoul use your synchronizing software.
Hope it helps
Aug 10, 2009 | Transcend T.sonic 610 MP3 Player
How to remove write protect on my usb flash drive
On USB stick, there is a "Lock/Unlock" slide bar on the opposite end of USB port. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected. remove the lock
Oct 08, 2008 | Computers & Internet
Portable Multimedia Player Sony k-965 Made in Japan Free driver download
how to play mp4 files in my multimedia player
(Portable Multimedia Player Game MP4 2GB 3"LCD screen) then what u mean by mp5 file
Aug 04, 2008 | Audio Players & Recorders
Boot failure
1st go to Ihttp://www.shamrockman.net/ and dload the version you want to run. My PMP shows 1.23 but I couldn't find that version so I now run 1.24.. Save the dloads in a new folder on your computer.. There should be (7) items that dload to your computer.
*** I have found that just copying the files to your PMP Player will NOT work.***
I had to delete ALL (7) of the system files and folders.
1.) BMP folder
2.) etc folder
3.) system file
4.) (4) "Version-[0x..... " files..
So there were (7) items I had to delete. Once deleted go to the folder you saved the dloads to. I had to click and drag each item to the drive your PMP player is connected to. Once all (7) items have been placed on your PMP player disconnect it, turn off the power, wait a minute and turn it back on. These steps worked PERFECTLY for me. Please let me know in this forum if this helps..
Thanks..
Jan 08, 2008 | iRiver PMP-120 Digital Media Player
Boot failure
1.) BMP folder
2.) etc folder
3.) system file
Thanks..
Jan 02, 2008 | iRiver PMP-120 Digital Media Player
Problem regarding my pmp player camera
my chinese mp4 player hang on the first screen. please help
Oct 05, 2007 | Photography
Shinco PMP-1700 Portable DVD Player with Screen Logo
125 people viewed this question
Top Shinco Televison & Video Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
