Question about Dell Precision Workstation 470 (204816690) PC Desktop
Power off My dell 470 it's stand by when i'm using, but I must switch off and power on again to use it. That it's very often. What can I do?..
  • jaime_farias Jan 25, 2009
    other detail, when I restart my dell 470 i can use for a little time, but it's "stand by" again. I'm very sad for that.
  • 140 Answers
You can either turn off the "standby" option in your power settings or make sure your devices (in your device manager) are set to "wake from standby". This is important for USB devices, Keyboard, mouse...etc.
Posted on Jan 25, 2009
Question about Dell D220P 01 Optiplex AC/DC Adapter 220-Watt Power Supply HOW DO I USE THIS UNIT TO PROVIDE 12V STANDALONE POWER?
most power supplies have a switch for 120 and or 220 options just move the switch to what setting you want. most power supplies can be used as a stand a lone power supply, if not than you need to request for a 220 watt power supply the can be used as a stand alone for pc or computer use. most computer retail should have them in stock. look on line or at
type power supplies stand-a-lone 220 watts computers compatible
Mar 02, 2015 | Dell D220P 01 Optiplex AC/DC Adapter...
Dell precision 670 diagnostic lights y g y
Click on -
Dell Precision Workstation 470 and 670 Computer User's Guide
In the list on the right side, click on - Tools to Help Solve Problems
In the list on the left side, click on - Diagnostic Lights
Yellow (A) Green (B) Yellow (C)
"A possible VRM 1 failure has occurred"
VRM stands for Voltage Regulator Module.
It regulates Voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much; and the Processor turns off. (BIOS turns it off)
Your motherboard supports two Processors.
1) Processor (CPU_0) Zero which is in the middle of the motherboard, next to the PCI Express x16 slot;
2) and Processor (CPU_1) One, which is next to it.
The VRM 1 has failed. Needs to be replaced.
VRM's used are interchangeable.
IMHO you can remove Processor 1 (CPU_1), and it's VRM, and still use the computer; albiet slower though.
For additional questions please post in a Comment.
Mar 22, 2013 | Dell Precision Workstation 670 PC Desktop
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
What type of vga card do i need for a dell precision 470
To take Full advantage --You have High-Speed PCI X (express) slot-(if its not already being used for something else)--and dont forget that you will need to disable the integrated one first.
Jan 02, 2011 | Dell Precision 470 PC Desktop
My dell precision 470 keeps burning video cards
Have you replaced the power supply at some point? You may have the wrong power supply...Your processor may not be able to handle the Graphic Card that you're trying to use...Graphics cards are very demanding on a computer and you may have pushed your computer beyond its limits with regard to how much graphics it can handle...
Oct 29, 2010 | Dell Precision 470 PC Desktop
My dell percision 470 is dead. Don't know if I need a new power supply or motherboard. Dave Moll
you can check the power supply by voltmeter if it works then may be mother board is dead
Aug 18, 2010 | Dell Motherboard For Precision 470...
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Green power LED on front panel; Green STR_LED on motherboard; Yellow AUX_PWR LED on motherboard; No beep or VGA...
sounds like a motherboard failure.
Basic troubleshooting, disconnect all external connections except power, see if indications change, if no go remove all expansion cards see if any change, if no go disconnect all drives see if any change. If none, then motherboard.
If at any step you get a change in indications, then see if you can isolate the faulty item
DIAG LED info is here
Jun 15, 2010 | Dell Precision Workstation 470 (204816690)...
PC monitor not lighting up for around 10 mins
Check the capacitors on the power supply board inside the monitor. They malfunction, heat up, leak or pop and stop doing what they are designed to do, smooth out the power supply to the inverter and display board. You can replace these simply by buying the correct farrad, voltage and temperature rated replacements online for about .30 a piece or go to radio shack and spend 1.50 a piece. You can use a higher voltage like 35V instead of 25V but try and get the 105c rated ones to last longer in the hot P/S environment. My bad ones were 470 micro farrad, 25V and 105c rated and I had 4 out of 8 pop or bulge.
Apr 08, 2008 | Computers & Internet
Canon 470 printer scanner stopped scanning, Bill
Feb 28, 2008 | Canon PIXMA MP470 All-in-One Printer
No power
Try it in another powerpoint. Try uninstalling it and reinstalling it on pc if not a stand alone unit. Could be the power support has died and may need repalacing.
Aug 16, 2007 | Dell 1600n All-In-One Laser Printer
Computers & Internet Logo
162 people viewed this question
Alun Cox
