Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Epson rx 420 comunication problem
Pc says comunication error. i have to turn printer on and off three times and then it will print?when i turn it on for the first time the pc finds the printer and the pc says this item is working ok.but as said will not print just get error come up.reinstalled drivers.used new usb lead.changed ports.can anyone help.
Try with another USB cable.
Posted on Nov 17, 2007
    Genius:
  • 2,985 Answers
But you install the software precisley as instructed? Remove all Epson software from the computer. Do a disk and registry clean. Come off line and disable the A/V software. Disconnect the printer Now reinstall from the disc and do exactly as the prompts. Epson is very fussy in installing .
Posted on Jul 12, 2007
I have a Epson Stylus All in one Rx 420 I am searching the drivers for Windows 7
From http://esupport.epson-europe.com....
...If your product is not listed, where available please download and install the Windows Vista driver from the Epson website...
Here is the link to the vista-drivers for your product
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-IE&data=nKGrQtfEm6nklAFAU002FI5XulUnXahGGzFymQyp3UZx8RYU003D&tc=6
Jun 03, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Epson PLQ20 Passbook printer Problem:"comunication Error"
Hi, Check your cable connection. Check for updates from Epson. Restart your computer . Good luck.
Jun 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
Epson Stylus T60 Communication error 68 problem
i have 2epson t60.i try print cd same time in one image.
i have a erro massage comunication erro.why this
(my english grammer poor.sorry for that)
Apr 29, 2011 | Office Equipment & Supplies
I have an Epson Printe RX 420 and now an E has appeared while the green lights go on and off. What to do? many thanks, Yvano
power off printer.check for obstructions/foreign objects. remove obstructions/foreign objects. power on printer.
Jul 06, 2010 | Epson Stylus RX425 Multifunction...
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Connection problem with parallel to USB cable
Toriom,
Uninstalling the driver and reinstalling the driver is a veriable solution, please try it.
I'm surprised that Epson does not have an LA (Latin America) center.
Don
May 04, 2009 | Epson Stylus Color 480 InkJet Printer
Epson RX560 problems photo printing
RX 560 a printer error has occured see documentation
Sep 03, 2008 | Epson Printer
Epson rx 500 print problem
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Jan 07, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
Printer not printing Epson Stylus RX500
What does the error in the status monitor report?
Switch on the printer, and under Printers And Faxes in windows right click on the RX and select properties
Click on Printing Preferences and then select the maintenance tab, select the Status Monitor and report what it says in the box in the middle.
From here we will be able to help you.
Oct 16, 2007 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
103 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
