Question about DOD 231 31 Band Per Side Equalizer
DOD SR231 QXLR COMMON ONE CHANNEL FAILURE
DOD SR231 QXLR COMMON ONE CHANNEL OUT FIX
I'm looking the power cord for DOD 1642 16 channel professional mixer Somebody can help me
Are you looking for the power cord or power supply for your mixer?
Nov 03, 2013 | Music
Philips lx3000
reason of Stereo no sound:
1 poor contact,signal line,socket connection problem.Acoustic power and signal wires to check clearly good contact.
2 Most common failure is bad capacitors,amplifier or power amplifier tube burning,this is our problem,but most of those are the devices themselves are not stable.
3 there happens no sound from one channel of the power amplifier failure,problem or circuit problem.
Nov 02, 2013 | Audio Players & Recorders
Backlight no working
Since you dod not provide the make and model, you just have to look here to what is like to replace the backlight inverter board which is a common failure.
www.insidemylaptop.com
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 02, 2011 | Computers & Internet
Sound cuts out
Hi Darren.
I suspect you may be right about the eq here, though you probably have had it sorted by now.
I came across this thread because I was searching for a fix to my R-231 and was hoping you might be able to help me if you found a fix. I'm persisting with this one as I can't really get another just now and it seems that it's not a major issue. I managed to get a good signal out of it when I ran it without the ground connected on output???
Anyway, any info I would greatly appreciate,
Thanks, Rob dronno@live.com.
May 20, 2010 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How to connect a sr430qx equalizer to abpm500 gemina mixer and a carvin dcm2000
All of three of these components have balanced connections. There are many different ways to connect- but this is the best option. You will need 4 x standard XLR3(cannon) mic leads. Starting from the Gemini mixer:
take the left output and plug it into channel 1(A) of the DOD EQ
take the right output and plug it into channel 2(B) of the DOD EQ
then...
Connect the EQ output of channel 1(A) to the input 1(A) of your Carvin amplifier
Connect the EQ output of channel 2(B) to the input of 2(B) of your Carvin Amplifier
Happy DJ'ing
Rus.
Feb 19, 2009 | Dual Audio Players & Recorders
Collapsed lifter
if it is higher mileage i would replace all of them since you are already tore down to replace one. it is not a common problem.You could replace the one and never have another problem just never know.
Jan 29, 2009 | 2006 Chevrolet Trailblazer Ext
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 03, 2007 | HP Photosmart M425 Digital Camera (5MP,...
DOD 231 31 Band Per Side Equalizer Logo
43 people viewed this question
Top DOD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DOD Audio Player and Recorder Expert? Answer questions, earn points and help others
