Question about Kyocera Copystar CS-1620 Black and White Copier
KM 1620 ERROR C6000 - Kyocera Copystar CS-1620 Black and White Copier
SOURCE: C-6 ( 400 )
KEY IN 1087 TWICE N PRESS START, ENTER CODE ERROR EG.400 N PRESS START. ONCE IT SHOWS CLE, ENTER 163 N PRESS START. WAIT FOR IT TO RESTARST. LALI.
Posted on Jan 27, 2010
shawn38
  • 200 Answers
SOURCE: photocopies displays and error message that reads 400 then C-6
It most likely can be reset over the phone. Go to www.gfbm.net and call. They can walk you thru reset over phone whach should correct the problem at no charge.
Posted on Feb 19, 2010
SOURCE: Kyocera Mita KM-C3232- Error Code C6000
The power source board may have created this problem and replacing the fuser may only be a temporary fix and after replacing the power source you may to replace the fuser again.
Posted on May 11, 2010
  • 903 Answers
SOURCE: Kyocera KM-1620 as a printer??
Yes, it can be connected as a printer -- see this page where you can download the print drivers:
http://usa.copystar.com/americas/jsp/Kyocera/download_center.jsp?pid=11917&pcat=10564&rcid=10009&rscid=10007#bottom
However, it may need an optional interface attached. Check the back of the machine to see if there is a USB port (the squarish one). If there is nowhere to plug in the USB cable, you may need to buy the printer interface option.
Posted on Jul 07, 2010
M2Tech1
  • 313 Answers
SOURCE: Error E31
this is an error code for slow warm up you should pull the fuser out and check the thermistors and condition of the rollers. sometimes the thermistors get caked in toner so they cant read the temps correct. if you take the unit apart you should be able to detect the toner build up. a soft clothe and some WD40 may be able to clean it off but be ccareful as too rough may clip ther resistor off.
Posted on Jul 12, 2010
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 ยท Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
Have error: C6000 on call for service c6000
The error code(C6000) Maybe the broken fixing heater wire. In fixing warm-up, the time to reach 50 degree(C)/122 F exceeds 10s, the time to reach the primary stabilization exceeds 10s or the time to reach secondary stabilization exceeds 24s. Or the Fixing heater M or s installed incorrectly. Check and re-install if necessary or replace the fixing heater M or S
Aug 23, 2014 | Kyocera Mita KM-2050 Printer
Error code A3200 for kyocera km 1620
how to repair kyocera km 1620, showing error message "A3" "200"
Mar 31, 2013 | Office Equipment & Supplies
KM 2810 error C6000
kyocera mita KM-2810 error code C6000 how to re-set and fix it
Feb 06, 2013 | Office Equipment & Supplies
Ererre c600 km 2035
Are you sure the error isn't C6000, which is a fixing unit error? If it is a C6000 then it maybe able to be reset in simulation mode if the fixing unit hasn't failed. Verify error code.
Dec 23, 2010 | Kyocera Mita RADF-11 REVERSING...
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
Have error: C6000 on Kyocera KM-3050
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Aug 02, 2008 | Office Equipment & Supplies
Kyocera Copystar CS-1620 Black and White Copier Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
