Question about Frigidaire Ovens
Model #PLEB27S8CCC Frigidaire Electric oven - Frigidaire Ovens
  • 1073 Answers
SOURCE: Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Posted on Apr 12, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Posted on Apr 26, 2009
localwonder
  • 6784 Answers
SOURCE: oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Posted on Dec 17, 2009
SOURCE: Require Electronic Oven Control Guide for a drop
the problem with the oven is that,when we start it to bake sumthing it turns of automatically after half and hour,and it doesnt bake anything...can you please help us with this problem...
Posted on Dec 21, 2009
ginko
  • 19396 Answers
SOURCE: how do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Posted on Mar 04, 2010
How to get manual for the Frigidaire electric wall oven 27 inches?
You have several questions on here with diferent models, i suggest you go to the frigidaire website under owner support and register your model for a manual download. http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/undefined
Jan 20, 2015 | Frigidaire 27 Inch Stainless Steel Wall...
How do I find the manual for a Frigidare Electric Oven
you have several questions on here with diferent models, i suggest you go to the frigidaire website under owner support and register your model for a manual download.
Jan 20, 2015 | Frigidaire FEB27S5A Electric Single Oven
How do I remove the oven door of Frigidaire Model
Hi.
Regards.
Mar 04, 2010 | Frigidaire GLEB30T8A Electric Double Oven
I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Jun 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven doesn't heat
Its are a wall oven or range???
Model number please
May 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
46 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
