Question about Ricoh Aficio Office Equipment & Supplies
5001 RICOH printer is printing dark spots
When you print, the copies have smear marks. Leaves gray smears across the sheets.
jaylex
  • 417 Answers
SOURCE: Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Posted on Feb 21, 2008
mitpatterson
  • 74 Answers
SOURCE: samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Posted on Jul 18, 2008
Corysf62
  • 188 Answers
SOURCE: prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Posted on Oct 04, 2008
POCBM
  • 121 Answers
SOURCE: All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Posted on Mar 28, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 7400DX - leaves "smudges on the printed sheet
It sounds like you have a developer housing failure.
Posted on Mar 29, 2009
Printing vinyl
Go to advanced settings on the printer control panel, and look for the type of paper. You may also need a special quick drying ink to print, otherwise, it will smear, and if it doesn't smear, it takes forever to dry!
Nov 16, 2013 | HP DeskJet Office Equipment & Supplies
RICOH 1224C COPIES ARE SMEARED
Smeared output can also result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
If this does not resolve your issue then make sure the fuser is heating; if not, the thermostat is bad and you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
May 12, 2010 | Office Equipment & Supplies
The copies are coming out smeared and with lines. I wiped the (drum?) off?
What did you wipe the drum off with???? That is why you have this problem. You may want to try recleaning the opc with a dry soft rag, also you may want to clean the drum blade... If that dose not solve your problem, you may need to replace the opc & blade... Have you tried to stop the copy before it gets to the fuser unit.. If so, are the marks there???
Jun 02, 2009 | Minolta EP1083 CS/PRO Copier
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
When printing the printer is leaving smears on the left side of the page and random letters. If I make 20 copies, the first 5 and the last few will have the marks. I already changed the drum and all...
you need check
1) you may make sure the smear occur after the photo drum unit or after fuser unit, you can stop printing when the paper goes around between the drum unit and fuser unit,
2) clean or change fuser leaner if the random smear occur after the fuser unit(not after the drum unit).
3) still check new drum unit there is a cleaner on it, it could be the smear occured if not enough cleaned drum surface
hope you fix it
May 06, 2009 | HP LaserJet 2840 Printer
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
I am having problems when printing out a copy from my computer.
if run your figure across the print, does the print smear?
if os, yu need a new heater element, if no check the roller for dirt and print smear.
Jan 06, 2009 | HP Officejet J5780 All-In-One InkJet...
Streaked & smeared printing on envelopes
Check area where the envelope is pulled into the unit. There may be some debris causing the ink to smear.
Sep 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Samsung CLP-300 dark prints and smears
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
