Question about GE Profile PSS26NGS Side by Side Refrigerator
My ice maker stop putting inside of tray.
The dual water valve doesn't work on the ice maker side.
  • Anonymous Apr 03, 2009
    i Replaced the dual water valve on my ge profile side by side fridge the icemaker worked one time.
  • 61 Answers
MOST GE NEW ICE MAKER IF THE GREEN LIGTH IS ON THEY ARE ON . IT MAY BE THER WATER VALE NOT LETING WATER IN OR IT MAY BE THE COMPLEEDS I/M. YOU CAN;T GET PARTS FOR IT YOU MUST REPALCE THE COMPLEDED UNIT.CALL 800-614-2700 TO GET PRICE ON PARTS. AND HAVE MODLE # REDY
Posted on Jan 25, 2009
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
GE bottom freezer ice maker not working
Remember there are two sides to a dual water control valve, the water to dispenser side and the side that feeds the ice maker. Replace the WR57X10094 Dual Water Control Valve and I think you will be good to go on ice, Thanks Sea Breeze
Jul 02, 2012 | Refrigerators
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Sep 18, 2011 | Refrigerators
Water to ice maker does not shut off after filling tray
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Sep 03, 2009 | Maytag PSD2450G Side by Side Refrigerator
My ice maker has stopped working
The problem is most likely the water control valve on rear of refrigerator.There are two sides on what is called a dual water control valve. If I had your model number I could tell you the part number. The second possibility is the thermostat inside the ice maker is defective. The way to test is to fill ice maker with tap water let freeze and if it dumps and does not refill then the water valve must be replaced. Let me know and please rate my solution, Thanks, Sea Breeze
Aug 13, 2009 | Freezers
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSS26NGS Side by Side Refrigerator Logo
63 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
