Question about Intermatic EI210 Electronic Auto Shutoff Timers
Can the Intermatic El210 be set to turn things on and off?
I am trying to find a timer that can turn something on for 5-10 minutes then shut it off once every hour for about 10-12 hours. Can this timer do this? No one at the hardware store could answer this.
  • 10,865 Answers
You will need a more sophisticated timer than most hardware stores carry. Go to Smarthome.com and click their timers and automation section. There you will find many levels of sophistication in timers. good luck
Posted on Jan 25, 2009
How to remove a Intermatic 30 Minute Spring Wound Timer FF30MC
10-22-12
FF30 Intermatic timer: The turning knob pulls off.
(With some really old models, 1960s, there is a small set screw on the fat end of knob.)
Under the knob is a small hex nut that twists off to remove plate.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://waterheatertimer.org/How-to-wire-switches.html#gang
Oct 22, 2012 | Spring Step Intermatic 30 Minute Spring...
Cannot find the WEEK button on the DT300 as referenced under TO REVISE A SETTING. have not been able to get both of my timers to turn on the lamps i have programmed, perhaps this has something to do with...
Open following links to identify timer.
If you have different timer, then add a comment.
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
I do not see a week button either, and sure enough the Intermatic manual says press the WEEK button to revise ON OFF times. The GE manual says exact same thing. And so does the Woods manual.
I think what the instruction means is this:
To revise programs, press Progam button as many times as needed to arrive at the program you want to change. For example program1 ON or program1 OFF etc.
Then reset the program as shown in step 5 using the Hour button to set Hour, and Minute button to set minutes, and day button to select the days or blocks of days (including all 'week' as one of the choices).
Both timers will not operate?
I test timers and a percentage arrive defective. There is no repair for defect timer. This timer has 1 year warranty.
There is no load rating on this timer, at Intermatic, GE or Woods. Timer is older style and probably rated for 500-800Watts incandescent light bulbs only.
Also test outlet with circuit analyzer to make sure polarity is not issue. This is a polarized timer, and outlet wiring must be correct for electronic timers.
Make sure each program has ON and OFF time. So set program1 ON, and then set program1 OFF. And make sure same days or blocks of days are selected for each.
When setting on and off times, make sure there are no overlaps or conflicts that cause timer not to function correctly.
Another thing is setting timer for 12:00 midnight. It's better to select 11:59pm so the day is clearly understandable to timer.
When reading complex manuals, I write out the steps until things are clear.
Sep 25, 2011 | Hardware & Accessories
My Intermatic sprinkler timer's 'auto" switch
You can replace the 133T1115A switch if that's the suspect part:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Other than the switch, the only other thing affecting timer would be the trippers.
Feb 09, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
When setting the timer (model 12-817) power is activated between the hour choices (2 hr, 4 hr etc) but the power goes off when the dial is turned to the actual hour selection. If left between the hour...
What timer is this?
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Sounds like a defective timer.
I have three Intermatic spring wound timers that are used every day, and never have that problem.
After all, how does the timer 'know' when it's set on the 'hour' since the dial does not have stop points at specific times?
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic FD60MH Energy Controls -...
My model TN600CL lamp timer goes on fine and turns off at the times set but when it turns off at night in about 15 minutes or so it turns on again by itself. what gives?
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn600cl.ashx
If timer is older: The OFF tripper may be worn so it doesn't turn switch OFF completely ... and when tripper passes the switch, the switch pops out. Same thing happens with box-type electro-mechanical timers when tripper wears out.
Make sure trippers are pushed all the way in toward the center, and tripper is snapped on place.
If timer is new, and trippers are pushed all the way in, then timer sounds defective.
Nov 15, 2010 | Intermatic & Lighted Dial Timer
10 year old timer will not shut off any more
It's broken.
I have a FF series countdown timer on a water heater circuit that's been used for past 4 years.
The FF and FD series timers are heavy duty, spring-wound countdown timers.
I expect 10 years is a good lifespan.
You can buy a new spring-wound countdown timer at Home Depot or Lowes, but new ones are lighter weight than the good ol' Intermatic.
Grainger sells the FF60 (60 minute, metal cover)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-6X546?Pid=search
Grainger shows the FD60 (60 minute, plastic)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-1XC27?Pid=search
Grainger Intermatic timers shows a lot of FF and FD timer choices:
http://www.grainger.com/Grainger/intermatic/ecatalog/N-1z0r56r
There are several pages of Intermatic timers:
FF5minute thru FF12hour
FD15minute thru FD60minute
Nov 09, 2010 | Intermatic FF12HHC Energy Controls -...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Intermatic EI210 Electronic Auto Shutoff Timers Logo
146 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
