Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Why dose my washer keep throwing belt - Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
  • Frigidaire Master
  • 17,130 Answers
It can be due to problems faced by poor alignment of the motor, pulley and shaft. Also it can be due to worn belt or tight spindle that makes the belt slip over. check the free movement of the spindle and pulley , if not the assembly must be reset.
Posted on Jan 17, 2013
Encore mower keeps throwing the belt off
are the belt guides installed in the right place a lot of times the belt guides are bent out of place allowing the belt to jump off
Sep 01, 2012 | Encore Garden
I have a Neptune series washer that keeps throwing the belt. I took off the back cover and found that it has been digging into the plastic back and has worn the belt down a little. Are there any tricks to...
Take the center bolt out of the pulley remove the large washer that fits into the pulley flip it over and re-install it and the pulley will cease to wobble.
Sep 21, 2009 | Washing Machines
Whirlpool top load belt driven commercial --spins while agitating
tobe a belt driven wp it would have tobe pretty old,if so its down in the cam bar area.the feet or plungers break and the cam bar dose not pull back.i would remove cam bar and file to clean up or replace if to worn along with new plunger.also use lite greese on cam bar where it slides and on bottem of blungers.also check the condition of your wig wag[control magnet.May God bless your house,tom
Jan 02, 2009 | Whirlpool GSC9455 Top Load Washer
Equator ez2512 washer dryer keeps throwing the main belt off.
somthing is going to be obvious there.you have to inspect it whatch it while it runs
Dec 31, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Keeps throwing belt
Check the pulley on the back of the basket to see if it is loose or the center key is worn out.
Oct 27, 2008 | Kenmore 46462 Front Load Washer
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Belt comes off
maybe not, is the belt condition good, if so check for any wobble on the pulley, you may have worn drum bearings, this will cause the large pulley to wobble and throw the belt when it spins, also you can check the belt for being tight, it should be fairly tight but not tight enough to cause it to snap, if loose there should be adjustment at the motor end on the motor housing, all of this is assuming this is not a brand new belt, if so have you bought the right one?
Sep 27, 2007 | Kenmore 43042 Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
