Cisco cable box error code 1a09 - Computers & Internet
  • 55 Answers
SOURCE: have connected wii to cable via cisco asa 5505
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Posted on Aug 09, 2011
r_jansen3
SOURCE: bose cinemate II control codes for cisco cable box
Try 01582
Posted on Mar 06, 2012
ercupa190
  • 12223 Answers
SOURCE: what is the code for new cisco cable box
go for www.fitness.manualsonlne.com or www.remotecodelist.com
sincerely. God bless you
Posted on May 07, 2012
gopakumarg43
  • 74666 Answers
SOURCE: need code for cisco cable box.
0038,0031,0037. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 14, 2014
gopakumarg43
  • 74666 Answers
SOURCE: I need codes for Cisco cable box I have remote # 24944v3
270,277. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 22, 2015
Cisco cable box dta50 codes
Sir
I suggest you follow below link to resolve your Belkin Router issue:
http://www.cisco.com/c/dam/en/us/td/docs/video/at_home/Set-Tops/DTA/4030042_B.pdf
Troubleshooting Router Interfaces and Modules Issues
Or
In Case You still Nedd online Cisco Router Help Then I Suggest you follow us on for
CISCO Router Support
Mar 17, 2014 | Cisco Computers & Internet
Connecting Cisco 851 cable to virgin media super hub Problem
are you using the cable modem as your router? if so then simply hard code your media hub to a static ip address in the same range that the router/modem communicates on. (private address side)
Dec 27, 2013 | Computers & Internet
Problem with blu-link remote connecting with Cisco rng100 cable box
0029.0024,0029,0021. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts. Check this link too. http://electro-medical.blogspot.com/
Dec 14, 2013 | Interlink BLU-LINK PS3 UNIVERSAL REM
I need the remote code for Cisco cable box, model 9865HDC
This may not be a definite answer, but it may provide a hint what codes to try. Although the standard Cox cable box code for my Philips universal remote, 4200, worked for the 9865HDC, the standard code for my GE 24959, 0529, did not. Since Cisco acquired the Motorola cable box division a few years ago I tried all of those codes, but none worked. Then I noticed a single code 0506 for DVR under Motorola. It worked like a charm, even the dedicated DVR List button on the GE 24959. Hopefully you can find a Motorola DVR code for your universal remote.
Sep 26, 2013 | Cisco Computers & Internet
Device code for cisco RNG 150
Ok I know the post is kind of old, I mean the person asking about wanting to find the code for comcast Cisco RNG 150, all depends what Bose system do you have, the system I got is Cinemate GS series II that comes with an universal remote, and the codes for the Cisco brand cable box, it doesn't specify model code only Cisco cable box, anyways the codes are, 01877, 00877, 01982, now the last code worked for my universal control, don't know if it will work with other Bose controls, one thing I found out while browsing is that someone posted a cinemate manual with some codes but not for Cisco cable box they were for scientific Atlanta that are boxs comcast uses for the digital preferred system, the Cisco is use also for digital preferred but it has a different code, out of the three codes I posted earlier the first two were the same as the codes for the SA cable box, but the third one 01982 worked for mine. I hope this information will help someone. CEVICHE!!!!!
Jan 13, 2012 | Bose Cinemate Digital Home Theater System...
Need the five digit code for the cisco cable box model 4642hdc to program my tv remote
I have vizio 42 LCD I need the five digit code for the cisco cable box model 4642hdc to program my tv remote
Jan 26, 2011 | Televison & Video
Need device code for OneForAll URC-3220
I have a book for a later model oneforall and it don't have a Cisco cable box in it. I think if the remote came out before cisco started making cable boxes its going to be hard to find. Good luck.
Mar 03, 2010 | Televison & Video
Att uverse codes/Cisco dvr box
is ipn 330hd the model number for the cisco scientrific atlanta box
Apr 28, 2009 | Televison & Video
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
