Question about Maytag SkyBox MBV1976A Beverage Dispenser
Ordered a generic relay switch for my older whirpool freezer old one has only one prong for the red wire the new one has four does it matter which one i hook the red wire to
    President:
  • Maytag Master
  • 2,651 Answers
It sureshould matter, did the new awitch not come with an instruction???
Posted on Jan 25, 2009
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
Wiring conia ccd4501
There could be two situations for you. For the wall outlet, you may have a four prong plug or a three prong plug. For a three prong plug the outlet has three prongs and the terminals inside match up with these prongs. The two slanted prongs on the top are the hot terminals and the red and black wires get connected to these (order doesn't matter but keep the wires matched up with the terminals on the same sides). The white wire is connected to the "L" shaped prong, the third lower prong. The bare copper wire is just bent out of the way. At the dryer for the three prong there will be three terminals 2 hot and one neutral. Usually, your dryer cord will have the neutral as the middle wire, but pay attention if your cord wires are color coded (where white will be your neutral wire). At the dryer there is a terminal which is connected to the frame of the dryer by a piece of metal. This is your neutral, connect your neutral wire from your cord up to this. The other two wires get connected to the other two terminals (order doesn't matter but keep the wires matched up with the terminals on the same sides). For the four prong its very similar but there is a small change, that bare copper wire is now used. The terminals on the wall outlet will line up with the prongs. The two vertical terminals on the left and right are your red and black wires. The "L" shaped prong is your white wire. Now the fourth prong, the one shaped like a semi circle is the terminal you connect that bare copper wire up to that is your ground. At the dryer for the cord (If its a four prong cord your wires should definitely be color coded). The terminal that had a connection to the dryer frame now will no longer have one. The terminal thats connected to the frame you connect the green wire to. The terminal that was connected to the "green wire terminal' is now the neutral terminal and your white wire gets connected to it. The other two terminals are where your connect your last two wires.
May 10, 2010 | Dryers
Change the dryer cord from 3 prong to four prong
If its a four prong cord your wires should definitely be color coded. There should be a black, red, white, and green wire. Since the dryer was a 3 prong wired dryer originally your going to see a terminal that is (or was if it was removed already) jumpered to the frame of the dryer using a piece of metal. Your going to remove that piece of metal. Now the one terminal (not the frame) will be where you connect your white wire or neutral. The other terminal the the neutral terminal was jumpered to is where you will connect your green or ground wire. This allows for the dryer to separate the ground terminal and and neutral terminal in case of ground fault situation. There will be only two terminals left which are your hot terminals for the black and red wires. Order on these hot terminals doesn't matter however I recommend to keep it neat you don't cross any wires and keep each hot wire on the side it falls on.
Feb 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Generic relay switch
can you describe the relay to me?
the most common relay does have a specific place for the wire to plug onto. hold the relay with the holes that plug into the compressor upright and facing you. now turn the relay so that you are looking at the spade connectors(remember that the holes should still be upright) either one of the spades on the right side is the correct one to plug into.
if this doesnt sound like your relay message me back with a better description or a part number thx peyton
Jan 25, 2009 | Refrigerators
Prongs on dryer
Take old cord off. Remove wire or ground strap connecting dyer frame to center (nutral) terminal. White wire goes to center terminal. Green wire to frame (ground) Red and Black wires go to two remaining terminal, order really won't matter.
Sep 28, 2008 | Whirlpool LER5636P Electric Dryer
Install four prong plug kit
hi thanks for the question the green wire goes to the frame of the dryer other wires red to red white to white black to black thanks the appliance doc
Sep 15, 2008 | Kenmore 62872 Electric Dryer
Maytag SkyBox MBV1976A Beverage Dispenser Logo
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
